Inexpensive DIY Laser Depth Gauge
charlie belden
The former president of our turning club president showed this inexpensive DIY laser depth gauge. Can really help to avoid turning a funnel. Won't work if you do miniatures, but . . .
Re: Inexpensive DIY Laser Depth Gauge
Rob Wallace
Rob Wallace
Charlie -
It looks like you clicked on the wrong file to embed in this message. The image we got was the same as one posted previously in your work holding thread.
Rob
charlie belden
Rob:
Looks like the software is doing it again.
I checked my post immediately after posting and the the right image was there to see.
Checked just now and the right image is there.
So let's try a verbal description
Imagine an "F" and flip it horizontally so that the horizontal parts face left.
On the lower horizontal part of the backwards "F" there's a rubber conical tip
On the upper horizontal part there's a 1/2" T-fitting (think a T on its side)
A small pen sized laser is mounted in that T on its side pointing down towards
the rubber tip
The backward F is made up of 1/2" copper pipe fittings mounted on a threaded
metal pipe flange (think Face Plate) that's screwed onto a piece of 3/4", the latter
ply willl sit on the bed of the lathe.
The centerline of the lower horizontal part of the backward F is at the lathe
axis' centerline.
The whole thing can be mounted to the lathe in place of the tail stock.
When turning a bowl or hollow form, held in a chuck, the lower horizontal part
of the backward F can be inserted in the bowl or hollow form and slid towards
the headstock until it touches the bottom of the bowl or HF. The laser will
put a red dot ou the outside of the piece showing the location of the inside
bottom surface.
(A picture really is worth a thousand words)
Rob Wallace
Rob Wallace
Thanks for the reply Charlie - I checked this on two different laptops and Android phone - unfortunately the incorrect image of the old chuck diagram is still there, and there is no image of the laser depth finder . Can you try posting it again? Rob
Alan Zenreich
Alan Zenreich
I too see the image of the chucks
me 3
That's what I was thinking.
Let's try again
charlie belden
Alan Zenreich
Re: Let's try again
Alan Zenreich
Success, the photo now displays
Rob Wallace
TOUCHDOWN!!!
Rob Wallace
Thanks Charlie - Yes, a picture IS worth 1,000 words!
Rob
Bill Blasic
Re: TOUCHDOWN!!!
Bill Blasic
I bought this one off of Bill Grumbine, reasonably priced and can be used on different sized lathes.
Bill
Alan Zenreich
Re: TOUCHDOWN!!!
Alan Zenreich
Bill, I have the same Grumbine setup. I wonder if the copper pipe version needs the clamp in the base at all, as there is no need for one in our rigs, and it's not the kind of device one would want to lock in place... It's for a quick check.
Re: TOUCHDOWN!!!
I like it, but I have built hundreds of things out of copper pipe and and I can't imagine it is "accurate" enough for this application. The fittings are rather loose and I think this setup would be way too "sloppy". If you soldered all the joints it would be more rigid, but still fairly flexible.
Re: TOUCHDOWN!!!
Steve Worcester.
In the photo, the beam wouldn't be completely perpendicular to the point, which will cause a problem in thin walls. You could probably use right angle framing clamps to align while you solder or Jbweld into place
