Lidded Boxes with Finials
charlie belden
Turning lidded boxes and finials for them is a lot of fun, doesn't require much other than a scroll chuck, a skew, maybe a spingle gouge and a parting tool and a chunk of DRY wood (or several chunks of dry wood). And you can make them as simple or as complicated as you want.
OK, so there are only two parts to make, a third if you want to add a finial.
The lid has to fit the box and these two parts need to be aligned. The lid can fit INSIDE the top rim of the box or on TOP of the box. Either way you have to decide on how snug they fit together.
Now turners tend to shoot for a Pop Fit (when you pull the top of the box it should make a popping sound). This may impress other turners - but THAT requires using two hands to pull the lid off. And that means you can't have what you want to put IN the box - in one of your hands. Conversely, if you want to get something OUT of the box, you need one hand to pull the lid off and one hand to hold the box - leaving no hand to take whatever it is you want to get OUT of the box out.
So, from a User's perspective, a Pop Fit is inconveneint. A looser fit, that allows just the top to be removed - with one hand - makes more sense. Of course that may mean that someone will lift the box up to look at it more closely - and drop the box, and the content of the box, onto the floor. If the floor is concrete, tile or Italian marble, or even a hardwood floor, one or both of the parts of the box may get dinged - and you have to find all the stuff that fell out and bounced off to who knows where (usually they'll end up under something heavy and with little clearance under it).
Then there's the issue of Wood Movement. A Pop Fit when there's high humidity can become a loose fit when the air is drier, A Pop Fit when it's dry becomes, essentially, one piece of wood, rather than a box with a removable lid. Wood is, after all, hygroscopic and thus swells or shrinks with changes in humidity.
The other thing about finialed lidded boxes is that the finial, for aesthetic reasons primarily, is usually very pointy - the sharper the point the better - from an aesthetic perspective. BUT - picking up something that has a sharp point on it can make dents or holes in your skin. And if you have to wrestle the top onto the box and squeeze and / or twist the two together - a delicate, aesthetically pleasing finial - can be snapped off - or broken if the lid and finial are dropped on the floor (see above).
SO - my questions are:
Do you
Go with a Pop Fit when you turn a lidded box, and risk it being basically one piece of wood when the wood expands"
or
Leave a little slop and have it get looser as the humidity goes way down, increasing the likelyhood that the lid will FALL OFF when someone picks it up to look at it?
When it comes to the finial, do you
Go with the delicate, pointy topped, aesthetic finial?
or
Go with some semi aesthetic blunted finial?
IF you include a finial for your lidded box(es)
Do you prefer a Stuck On finial, with a bead or some other detail on the bottom of the finial where it meets the lid of the box?
or
Do you prefer to BLEND the finial and lid together so you get continuous flowing curves?
