Precision Router Mount on the Lathe
Steve Criscenzo
I have some design ideas that require a precise mount for a router on the lathe. I finally had a bit of free time today so I spent the afternoon fabricating a two part system.
First I made a base that attaches to the bed of the lathe. The base is fitted with two "T" tracks so I can use it mount other jigs. (I have plans to make a router table similar to the John Lucas model that I can mount to the "T" tracks. There is a guide bar that fits between the ways and two bolts lock it in place.
To hold the router, I fabricated a mount that attaches to a cross-feed vise. The router mount bolts to the "T" slots in the vise so it can be move and adjusted. The cross-feed vise mounts to the "T" track base. The entire vise can be moved along the tracks and lock in place with the two knobs. The movement along the track plus the two axis adjustment on the vise give lots of adjustment. (I also have a design for a rotating base in mind that will allow mounting the vise at an angle.)
I did a trial with the setup this afternoon. Worked like a champ.
What was fun was, that being the pack rat that I am, I was able to construct the entire unit with material at hand. I salvaged the cross vise from a trash pile a long time ago knowing that someday I would find a use for it.
If my design ideas come to work out, I will post the results.
