Great TAW symposium
Great TAW symposium
Great TAW symposium
I had a ball this weekend. didn't get to watch the demos I would have liked due to other duties but it sure was fun re establishing friendships. That's really what it's all about I think. Doug Fisher was really fun and informative. I went to only one of Barbara Dills demos and she does an excellent job of explaining a very hard topic. Gave you lots of room to experiment and grow. Trent bosh gives a really good demo that is very entertaining. Unfortunately I missed the one where he demoed using a mini camera to hollow with. Hopefully Josh Bowman will chime in on that because he did sit through it Unfortunately I didn't get to sit in on any of Kurt Hertzogs demos but heard some good compliments.
They had a good selection of vendors thanks to a better room than we had last year. The instant gallery was also great as always. Had a great conversation with Steve Sinner about dust collection. Hope he writes the article he said he was interested in doing.
If you have time plan for next year. It will be another good one I'm sure.
Re: Great TAW symposium
Josh Bowman
As always the Nashville folks put on a great symposium. I tried a different approach this year and set though all of Trent Bosch's demo's. I felt that they would kind of build on each other and they did in this case. He had a new gadget that I can't wait to build! If you understand hollowing with a laser, replace that laser with a camera and hook it to a small monitor. So now you see the hollowing tools last 3 inches or so. Trace that shape with a dry erase marker on the display. Now when you put the tool into the hollow form you now see on the monitor the traced outline of the tool that's inside. It's kind of like a detailed laser image or xray of the tool inside. The results are quick and accurate. Hope that didn't give anyone a brain cramp.
Benefits over a laser pointer?
Re: Benefits over a laser pointer?
Josh Bowman
That is a good question. I have used the laser for years and of course it only shows the pin point of where you set it in relation to the tools edge. And as long as you only use that edge to cut, it's fine. This system lets you see the whole tools edge in relation to the walls of the hollow form. Of course that's based on how well you traced the shape of the tool on the monitors screen.
Dick Coers
Yeah, how well you traced it and probably how wide of a marker you used. Guess I would have to see it to be impressed.
I didnt see it but josh said it does away with having to reposition the laser to be perpindicular to the wall where your hollowing to get an accurate reading. The downside would be having to buy a monitor of course I had a friend who used to mount a camera sideways on the lathe so you could see an image of the form in an upright position to better judge the form.
Lyle Jamieson
Lyle Jamieson
It works well with a cutter in a dedicated position. I have been doing this type of use for decades, only with the laser replacing the camera with my torso sculptures. For the multi-axis forms I do the hollowing first so I don't have the outside shape to follow. I follow the outline of a template with the laser like Trent follows the vessel with the camera.
I also use a swivel tip for my cutter. The dedicated cutter reaches most shapes OK, but I like the infinite range of motion from the swivel when the shape is difficult. I wonder how easy the TV is to re-set?? When using different boring bars or swivel it is a moving target. Its all about the gap. Every time the cutting tip moves to a new location to reach the inside shape, the Camera (or laser) has to move to keep the measurement of the gap perpendicular to the wall. The gap is the wall thickness works like any other caliper. It must measure 90 degrees through the wall.
It was sure a buzz around the symposium, with everyone talking about Trent's new gadget, cool idea.
