wire to burn rings
Earl
What kind of wire do you use to burn rings and where to get it? Do I need a different size wire to burn rings on pens? Thanks for any help.
Earl
wire to burn rings
Earl
Earl
Re: wire to burn rings
Dale Gillaspy
Start with smooth steel. not braided or twisted wire rope. Different diameter wires will yield different results, so it really depends on what you are doing. Your question about a different wire for pens really depends on different that what??? You could have a really fat line on a pen or a really thin line on a large bowl. I have 3 or 4 different diameter wires, and I turned handles for the ends of them to make them easier to hold. Whatever you do, don't wrap the wire around your fingers.
any wire will do
steven antonucci
echoing other's comments, don't wrap your fingers.
I have used copper wire (because I had it), and it works for a couple of bowls before it breaks. I have spools of it that I have inherited, and I just wrap them around a couple of sticks. Nothing fancy.
Steve
Re: any wire will do
Phil Powell
If you know anyone that plays banjo or guitar have them save you their broken strings or replaced strings. I use the two top strings off of my banjo to burn very small lines. Thinking about it if you have 4$ you can buy yourself a whole set of banjo strings. so you'll have tiny to big lines at your disposal. Phil
Jim Barbour
I use Nichrome (nickel chromium) wire for both wire burners and for custom tips in a wood-burning set. It is the wire they make heating elements from - I have yet to burn through a piece. It is not cheap, but several people can go together and buy a lifetime supply for everyone in different gauges. McMaster-Carr carries it, as do other places. see http://www.mcmaster.com/#nickel-chromium-%28nichrome%29-wire/=qhsetl
john Veerkamp
I use scrap electrical wire in various gauges. Strip the insulation and do as others said, use handles of some type. I've used both stranded and solid wire with equal success.
Re: Thanks all
Earl
I have some ideas to try now. I do have some copper wire and thought it would not work but I'll give it a try. Also thanks for the link to Mcmaster -Carr a bit expensive but might figure something out. I'm not very OSHA minded but I don't think I would have tried wrapping it around my finger (ouch). Thanks again Earl
It's all about friction. Run the lathe at a higher speed or wrap the wire about 70 to 80 percent t of the way around the piece and most any wire will burn. Don't wrap it around your fingers. If the wood grabs it you may lose a finger. About the only wire I've found that doesnt work is braided picture frame wire. I play guitar so use that mostly but have some copper wire in thicker sizes. It helps to cut a shallow groove first.
john Veerkamp
Second the grove.
Barry Rockwell
Mine are all guitar strings and wire fishing leader. Almost zero cost.
Speaking of zero costs
Dick Coers
I use Formica samples from the big box stores. I think it takes less effort and speed to get the burn mark. If I want a smaller line, I "sharpen" the formica on the disc sander before taking it to the wood. No handles needed.
Re: wire to burn rings *LINK*
Jennifer Indy.USA
Earl, this is what I use and recommend. Cheap, easy and safe because they come with "handles".
John Lawson
Interestingly, I DO use braided picture wire (it was what I had), and it works fine for me. I made garrote-like handles, and always cut a groove first.
jim miles
If you are doing big rings on big piece- any old rusty metal works fine - creates more friction
Yes, always cut a groove- so wire dosen't wander out of place
Soft woods- cut deeper- so it won't sand out
Copper can get hot enough to melt.
Yes, Formica- cut it in long strips - will burn line on the face where you
can't use wire
try narrow strips of hard wood for a bigger ring
