Putting finish in the cold weather
phillip Medghalchi
Ok, disregard that I am in S. TX and yes granted we don't get as cold as some of you folks get in your area. However, it finally got to us. Besides the weather report, I'd like to ask you guys that how do you put on the finishes on your turned and finish items when the temps. are this cold. Most of the finishes say do not apply unless you are in a very good ventilated shop, so I gather you guys won't open your shop doors for this purpose. And, if you don't open the door then you have to be running the heater or some heat source in order to do your work and you know you can not spray around heat, so what's the answer here?
I have been having problem with applying lacquer on my bowls then I have to bring the bowls indoor to get them to dry. but, we are running central heat which dries up the moisture inside and I have been getting some of my works to crack because they get too dry inside the house. I am hoping that you guys can share some knowledge here on this issue. i forgot to add that few of the bowls are for food use, so I put vatco butcher block oil on it, but it says do not apply the second coat for antoher 6 hrs which takes longer than that to dry since I bring it inside and we keep the house around 69° F not C.
Re: Putting finish in the cold weather
mjonesrdg
Reading the MSDS, "Watco", (not vatco) Butcher Block Oil, the material is a formulation of mineral oil (35%), tung-oil modified alkyd varnish,(35%) paint thinner,(35%) and zylene (5%).
To speed up drying in cold weather, you could create a micro-climate (in something like an ice chest with a 60 watt incandescent bulb) and keep your work piece and a container of the finish in temperatures controlled to about 85 deg. overnight...applying the warm finish onto a warm work piece, and returning it to the box to dry. If the MC is too high, before attempting this operation, you could experience some defect caused by too rapid moisture loss.
If this procedure does not produce the drying rate advertised by the manufacturer, you could then pour a small batch into a separate container and add Japan Dryer. (available at most paint stores, inexpensive, and will last your lifetime) Advise limiting the Japan addition to an equivalency of a cap full to a quart.
If this doesn't work, advise changing products.
Hope this helps, and hope that you report back your results.
I use minwax wipe on poly when I can't i use spray lacquer. I keep all my finishes in a heated steel cabinet with insulation. I use a 60 watt bulb with a thermostat it keeps my paints and finishes at 55 degrees.
phillip medgalchi
John, I appreciate your reply. I brought all my finishes which are in the cans inside and keep them in a small clear shoe box container in my office inside the house, so that keeps it from getting too cold. Now, I am not sure if I am doing the right thing because my shellac, lacquer, lacquer sanding sealer, contact ement are all in this box and kept on the floor which is little cooler in temp. that up on a shelf in the room. My qsn. was that how do you or where do you apply it on the turned piece considering that we don't have the optimal temp. available in the shop and can't leave the garage/shop door open and or close the garage/shop door closed while a space heater or in some of you guy's case wood burners going on. I will try your suggestion about the wipe on poly, although I have never used it. So, from what I understand spraying would be out of qsn.?
phillip Medgalchi
BTW, I can't edit my messages again.
Usually by early afternoon my shop is up to 50 so I put a layer on In there. I'm single so I move it to my kitchen counter for extra coats. It is 68 in my house. After 2 or 3 coats ill bit it very lightly with 4/0 steel wool. The. Apply one or two more coats. I'd its not glossy enough ill buff it with the Beale system
That's most of my work But for user bowls I do the same basic thing but use mahony's walnut oil instead of wipe on poly
Brad Vietje
Brad Vietje
Hey Phillip,
I don't know about spray finishes (I doubt they would work in the cold), but I have used Urethane Oil from the Craft Supplies catalog well below freezing. It takes longer to cure, but it seems to work just fine.
Like Watco, you apply liberally, let it absorb the finish for 20 - 30 minutes, then wipe off and allow to cure (usually about 24 -36 hours in worm weather, around twice that in the cold. I keep adding more finish until there are no more areas that look like they need more, and wipe off the excess. The oil seems to polymerize faster after the first application, presumably because the partially-polymerized oil already in the wood goes to work (catalyzes) the cross-polymerization of the subsequent applications, but I'm no polymer chemist.
I have used the stuff cut 20% with mineral spirits for the first application (better penetration and curing in the cold) followed by a second or third application uncut, right out of the can. Lots of people in Northern New England learned about using Urethane Oil thinned about 20% from Peter Bloch, the wooden lamp shade guy in central New Hampshire.
I haven't used that finish in a few years, but aside from the slight yellow cast it gives light colored woods, I have found it easy to apply and get good results, and when fully cured -- around 3 weeks in warm, longer in the cold -- you can either buff it with a Beale system to get more shine, or rub it back with paper towels or cotton cloths to get a more subdued look. YMMV, but I rather like the stuff.
Safe spinning,
Brad Vietje
Newbury, VT
phillip Medghalchi
Brad, much appreciated, I am going to look into it and see how it works in my climate. Well, if it works for you guys that you have so much cold weather most of the time up in your state, I have a feeling that It should work here. We just have been having this roller coaster weather down here and I like to get all those half finished projects done (you know how easy it is to procrastinate?)and clean out the space before I add on anymore half way done stuff to my already collections. Plus, Lyle is just about to ask me what the heck did I ever did buyinng his hollowing rig for? So, I need to make room for it to manouver it around. Some one should say "it's just about time".
