I have another lathe
I don't know what I'm going to do with it. It seems to be in good shape other than missing a tool rest. It was used for metal spinning in the IT shop at Tenn Tech where I used to work. I just had to bid on it thinking I would get outbid. I didn't so I'm picking it up next Tuesday (when the high is only 15- great) It has a 3/4hp 3 phase motor so I hope I can find an inexpensive VFD to put on it otherwise I'll be looking for a motor that fits inside that headstock which might be fun. I'll probably sell it after i get it done if I can get it running for a reasonable cost. It will make someone a good lathe. I usually sell the lathes I find and buy for about what I have in them so someone can get a good used lathe. I'd love to keep it and have it permanently set up for metal spinning but I have no room in my shop whatsoever ( and I'm not selling the Beemer to make room either)
Re: I have another lathe
Dale Miner
What voltage is the three phase needed to run the lathe?
I'll find out on Tuesday. I can't download the info anymore since they pulled it from the website.
looks like it will need riser blocks
Dick Coers
That's a lot of cast iron for that small throw. I wish we could get more user feedback on those Chinese VFDs on ebay to see if they are worth the trouble you might get.
walta
From the photo I do not think you can change the motor as the motors shaft and the spindle is one part.
Also you will likely find the speed changes are made by an electrical switch that connects 4 different set of windings to the 3 phase power. This head stock is really 4 motors built into one case.
If you use a VFD never change the original speed switch when the VFD is turned on as doing so would likely damage the VFD.
I think you should power the machine with a rotary phase converter if you want to use the original speed controls.
Walta
Brad Vietje
Nice Old Oliver
Brad Vietje
Those Oliver direct-drive lathes are nice machines. Technatool did NOT invent the variable speed, direct drive lathe, just BTW...
Two of my friends have older Oliver's, one like this, but with a longer bed, and the other is huge, with a gap bed that allows turning a table top all the way to the floor. I think you'll be very pleased when you get her hooked up.
Congratulations!
Safe spinning,
Brad Vietje
Newbury, VT
Harry Robinette
Harry Robinette
John
You can always fit another lathe in I have 8 in my shop 3 set-up full time and 5 that can be running in 15 minutes. Remember: it will all fit,it will all fit, just need to do some adjusting.
Oh ya my shop is only 24 x 25 with a small machine shop and one of most tools.
We all must play.
Nick Todd
Does any one thing the head stock & tail stock are not native to the ways?
Harry mine is 20x20 and there's litterly no room to walk. I have a larger dust collector and air compressor on the back porch that won't fit without some re arranging. I can't even walk around the planer and jointer with the new bandsaw in th way. Some very serious re arranging has to happen when the weather gets better
They appear to be original. It looks pretty clean. It came from the IT department at tenn tech so I doubt it was ever used much. They are mostly set up for metal classes for the engineering dept
I can help out with the bandsaw problem
Bart Leetch
Yes & I can help with the PM 3520 problem & the Delta Midi problem.
Now then you should have plenty of room.
I operated out of a 13.5x24.5 shop with a 7'10" ceiling for many years with a full complement of tools. Imagine cutting 12'x5' laminate down to the needed size in a shop this size.
I always wonder what I could do to help someone find more room in their shop after the experience I've had working every day in a small crowded shop.
In a small shop it sometime helps to not have hinged doors or have only sliding doors on cabinets, or have no doors at all. Sheet good sometimes get set in front of the cabinet.
Also having a shelf about 12" deep & 12" down from the ceiling or more depending on ceiling height all the way along one wall of if possible all the way around the shop to store little used items.
I made triangular shelf brackets with 2x2 along the top edge & back edge that went vertically along the wall. I screwed the bracket through the 2x2 with 3 long screws to the wall. The plywood shelf had a 2x2 on the bottom of the back edge that dropped into a notch in the top edge of the bracket back next to the wall & the front edge had a 2x2 the was screwed through into the end grans of the 2x2 on the bracket. so I just laid the shelf onto of the bracket back up against the wall & the back 2x2 fell into the notch & I screwed through the front edge 2x2 into the 2x2 end grain of the bracket. With the shelf stacked heavily I could do chin ups on the front edge.
