Don't Forget Turning Chat Tonight 9:30 Eastern
Re: Don't Forget Turning Chat Tonight 9:30 Eastern
phillip medghalchi
test
phillip medghalchi
Heck every time I try to log in it doesn't work, and I sure don't want to download other stuff on my comp with this chat platform company.
Stuart Johnson
What message are you receiving? It could be the one about updating to a newer version of JAVA. You'll need JAVA to access chat and I think you said you had gotten in last week so you have it on your pc. If so updating isn't adding anything additional. FWIW, I always deselect the two search options when I'm updating.
phillip medghalchi
Stuart this is what happens:
(sorry I couldn't post it here so I sent you an email with the file so you can look at it.
Stuart Johnson
I rarely use I.E. but it appears you either don't have JAVA installed or it is disabled. I have two I.E. on my pc. One has add on disabled and I got the same messages you showed in your email. I had no problem with other one that has JAVA enabled.
phillip Medghalchi
I checked everything that I could possibly do and can't figure out what I did the other night and if I got in and didn't change anything then youwould have thought I could get back in last night again?
Chat Access Problem
Stuart Johnson
If you have the latest Java and it's current then I'm out of ideas for I.E. You might want to switch browsers and try Firefox.
Java recently updated
I went to the chatroom on Monday night (in Chrome, as I *really* don't like Internet Exploder) and got a prompt that my current version of Java was not up to date. I quickly updated it and proceeded to the chat without a problem. ParaChat has become quite careful to only support the latest version of the Java Runtime Environment since there have been security problems in the past.
So, regardless of which browser you use, go to the Java site and make sure you're up to date.
