Saw this a few days ago -- may have been posted here by someone else (?).
A German guy turns a sphere using a slightly over-sized initial turning, then cuts a small groove with a parting tool before turning cross-axis using a pair of cup chucks. Very smart.
Many thanks to whoever called this to my attention -- I'll pass it on here:
Interesting will have to try the parting tool groove to see if it speeds up getting the ball roughed out. That's usually the slowest part for me. My friend Pat Matranga who has turned a lot of spheres is coming over tomorrow to play so I'll show this to her and see what she thinks.
I purchased some nylon rod about 3" in diameter. I'm going to make some new mandrels for sphere turning but wondering about the shape of the interior. I'm thinking I might make them with straight sides kind of like a sideways V but about 90 degree included angle or maybe wider. Anyone have any suggestions on the shape they use that works for them.
I'll be interested to read what you discover -- and how cool that you get to play around with Pat Matranga! She's done some very cool stuff.
I went out to the barn and made a set of cup chucks today (first turning in about 3 weeks due to sickness and cold temps) that were roughly hemispherical, and while they worked OK, I could see 3 issues with mine:
1. I made them about 1" diameter, which is too small for a 2.5" sphere. Smaller size leaves more wood exposed, but that isn't really needed.
2. I think flat sloped sides like the cone you described would make less of an imprint in the wood, and would work better.
3. The piece I made for my tail center doesn't sit quite true. I made it so it would sit flat on the little raised collar (I have whatever OneWay knock-off that Powermatic supplies), but may not have gotten the turned cup and the reference cylinder quite aligned, and left a little too much slop around the threaded 3/4" part -- went a little too quickly, I suppose.
I do like the groove as an absolutely round reference to a sphere when spun at 90 degrees -- I think that's pretty clever. Its easy to feel, but not that easy to see. Maybe coloring with a red crayon or something that won't bleed into the wood would be helpful (?)
Brad I doubt coloring it will do any good. I remember once coloring the homemade jaws on a chuck so I could see them better. Didn't work. Once they start spinning I guess color doesn't matter. I will try it and see.
I went back and re read everything. Should have save it or printed it out. I think I'm going to make the straight sided cup for the headstock and 2 for the tailstock. One will be the V shape and the other will be a small flat with an O ring. Hope I have time to make them tonight so Pat and I can play with them tomorrow.
Brad, it was I that provided that link but I couldn't make it a live link. Thanks for doing that. I got it from a friend that speaks German. He also said that the cup chucks should be no more than 1/3 the diameter of the sphere you are turning. He may have gotten that from the video. The idea here, of course, is that the bottom of the groove is a true circle and when that is turned away you should have a sphere.
The one problem with that method is that when you rotate it 90 degrees if the first turning of the sphere isn't dead on you won't be able to turn down to the bottom of the groove because the sphere will still be off center slightly. I can see where it might get you closer so the second or third rotation might get there faster.
I hope I have time to try it today but things are already mounting up that have to get done.
This is very similar to the method Christian Burchard uses for his spheres, except that he uses a pencil mark instead of a groove. He was born in Germany, so maybe he brought it over with him. I have been using his method for years, never needed a jig.
John, A quick and accurate method for true spherical cup chucks I learned from David Springett is to turn the chucks and rough out the inside. Then mix up some Bondo car putty and apply fairly thick to the inside of the cups while still mounted on the lathe. Wrap a sphere in a single layer of saran wrap, and press into the Bondo and bring the tail stock up until Bondo squeezes out. Let harden, remove the sphere and plastic wrapand turn the face true. Small air pockets won't affect the accuracy.
