Turning a Walnut Pedestal on General Spindle lathe
Chris Groves
I need to turn a pair of heavy solid walnut pedestals for a DR table I am building. I have glued up my blanks 8 x 8 inches by 22" long. I am questioning if my spindle lathe is robust enough to safely turn these large walnut pedestals.
Here is my General spindle lathe (weighs 175 lbs with 32" bed extension)... It is mounted on heavy metal stand . It is basically a heavy duty mini format lathe. It has a 3/4 HP variable speed motor.
http://www.general.ca/products/1_general/25_lathe/25-200.html
Since the blanks weigh 35 lbs I am a bit concerned that I may be overtaxing my machine...
I am an experienced turner... I also do a lot of large bowl turning on my Vega 2600 bowl lathe. I have done plenty of spindle turning but have not turned any large pedestals on this lathe before.
If I am careful to slowly true up the blanks is this a safe operation or should I turn these on larger and heavier lathe.
Thanks for your input.
Chris
