Just Playing With My Balls
bowlman
Here are a few pix of my latest endeavor. I have been experimenting with spheres for about a year now and I think I have gotten the hang of it. Tell me what you think. Woods are paduak, zebra wood, walnut, maple, maple burl, bloodwood and cocobolo.
Re: Just Playing With My Balls
Looks like your on the ball.
Nice!
Tony - Memphis
Any tips on making spheres? I have an order from my mother to make a 4" sphere for a sculpture she bought. Never turned one.
Thanks,
Tony
Dennis in Southern Oregon
Free hand or sphere turning fixture?
Dennis
bowlman
Tony, Dennis ...
Tips: take your time and practice practice practice.
I turned some of these using cu chucks using the method I first lerned from Richard Raffan. Others were turned using a jig. But, even with the jig, you need a way to turn off the "Nubbins". So, cup chucks. For balls 2 inches in diameter adn larger, I use vacuum chucks to hold them while sanding. Sanding ... not for turning off the nubbins. Finished by hand. And even with the sphere turning jigs, there is a fair amount of practice and setup required. They are just a tool, not a magic bullet. If I were only turning 1 - 10 or so, I'd use the Richard Raffan method. But, these are probably numbers 300+ that I have turned in the past 9 months to a year. So, I invested in a jig. Two in fact.
Hope this helps!
Steve Kubien
Steve Kubien
Really love the dark one in the 3rd picture with the deep grooves cut in.
Cyril Griesbach
Very nice spheres, Dick. I've been doing some myself but no where near the count you've achieved.
I found this video helpful. It's in German, I believe, so unless you speak German I suggest just turning the sound down and watch how he does it.
YouTube - Drechselkurs Söding 07 02 2009 Kugeldrechseln
great approach, Cyril!
GaryG in MD
I hadn't seen this method before, and it makes so much sense!
This is a great way to make a very accurate quickly and by hand.
Thanks for the reference. ...GG
No math octagon method.
Geoff Whaling
Nice balls, Bowlman.
For hand turning without a jig I still believe the "octagon method" is the easiest to learn & a no math version is easy to do.
Just draw a circle 2 to 3mm (1/16 to 1/8") bigger than the size of the ball you want on a scrap piece of timber.
Using a carpenters square, draw parallel lines through the centre and tangent to each side. Do the same at 90 degrees to the original lines and again at 45 degrees.
You now have an octagon that inscribes the circle. Transfer the octagons measurements onto your cylinder that the ball is to come from.
Turn down (part) to the spigotts diameter using a beading tool etc.
Knock off the corners using a skew, spindle/bowl gouge.
Then continue to knock off the corners to form the ball.
Reduce the spigotts even further then part off leaving a nub.
Centre between cup chucks to remove nubs and sand, repositioning the axis of the ball regularly.
Re: No math octagon method.
Tony - Memphis
I've been meaning to try that. I actually have a printout of that concept sitting on my lathe right now. I did a spreadsheet with lots of diameters for reference. There was an article in SAPFM recently about turning a square leg section into a round section by hand using the same concept. I believe there is an old rule of thumb called 7-17 or something like that.
Tony
RCH
7-10-7.
Used in all sorts of woodworking. I first encountered the rule in mast making. The timber was squared, then worked to an octagon, and finally to round.
That's how you hand shape spindles with a drawknife on the shaving horse. Square, then octagon, then round.
