Anyone know where they sell the more odd size thread chasers? I have the 16 and 20 TPI (and everyone seem to sell them) but would like to get some smaller ones (like 24 TPI) for small parts. Can’t seem to find them anywhere that ship to the states. Thanks for any help.
If I am not mistaken, John Lucas has made a set or two of threading tools from either bolts or cut-apart dies - I tried finding the past threads (no puns intended!) using Google on this topic, but could not find his instructions. Perhaps he can fill in how he made his thread chasers which can be adapted to different threading pitches??
Sam Angelo (Wyoming) also has produced some good videos on hand thread chasing which are searchable on youtube, and he might also be contacted for more information.
I tried some thread chasing a while back and it was somewhat fun, but it takes a lot of practice to get good at it (like everything else in woodturning!). Practicing first on PVC pipe and Corian helped develop technique before I moved on to hardwoods; I still was not very good at it - probably just needing more practice. (I decided to buy a Baxter threader jig instead (16 tpi), and I haven't touched the hand chasers since....!!)
I have made thread chasers in several different styles. Cutting a bolt in half and just using that. It's harder to do the outside threads because you only have sideways pressure.
I made some by cutting the bolt and silver soldering it to a flat bar to make the male and female cutters. This worked better because it more or less resembled the standard chasers.
I made my own from scratch using a bolt and tap to start the threads on the end of a piece of tool steel. Then filing with a diamond file until it matched the thread depth and size. I did this method because I thought the threads needed a slant since all the chasers I had see had this. turns out this is not needed.
Josh Bowman bought a Unichaser which is one tool that you use to do both inside and outside and it doesn't have a tilt to the threads so it would be quite easy to build this from scratch using just a diamond file and lots and lots of patience. Just use a thread gauge and a strong magnifier. File a little, check with the thread gauge and see where you need to remove more steel and file some more. That's more or less what I did after I used the taps to establish the initial thread in my article. It just took a little less filing.
I have been in touch with John on another form and he did offer some insight if I want to build some....not really my area of expertise. I have been threading for about a year now and after a long learning curve finally feel confident. I have the Baxter jig to though and use it when working in softer woods...great tool. Thanks a lot for your help Rob.
