heated tool handles.
I'm wondering if the heat thingies I put in my boots would fit inside a hollow thompson tool handle. that might be just the thing for these chili days. Maybe someone could market those.
Re: heated tool handles.
Mark Wollschlager
It probably would work, if you don't drop the shot out all over the floor.
I use lacrosse stick wrap on the handle.
It helps a bit with the cold and peels off with very little residue.
Chuck Engstrom
interesting idea. Or you could jam a suitably sized cork way up into the handle and use the whole thing as a flask for your hot toddies. By the time you get your hands warm you shouldn't be turning anyway and can go back into the house for another warm one.
I suppose the low cost, abundance, and easy machinability account for the common use of aluminum for handles. But that's probably the same set of reasons that make it the material of choice for heat sinks. There is no free lunch.
--Chuck
Dave Staeheli
I use "hot pockets" a fair bit. One thing is that they need a bit of air exchange. And they DON'T have to remain in the fiberous bag they come in. They could be opened and poured into a tool handle. But there would have to be some sort of screen so air could get into them and activate.
Re: Thermal mass
steve criscenzo
If your handles are filled with steel shot (I use sand), I would think that if they were warmed up before starting that they would stay comfortable for some time. When my shop gets cold, I bring my most used tools into the house overnight and it helps keep my hands from getting too cold. I have also used a radient heater aimed at me at the lathe to cut the chill. Works much better than a space heater.
Good news is that at least for my Oak Ridge site, temps should improve in a couple of days. Glad I do not live in New England any more.
Stay warm folks
Steve
Mike Stafford
I carry my thermal mass around with me...
Mike Stafford
But I don't carry it to the shop where it can get cold.
But aren't you carrying less these days.
Dale Miner
The low cost, ease of machinability, and availability also apply to wood, although it lacks the heat sink properties. It fact, insulation ratings are compared to wood.
Mike Stafford
Re: But aren't you carrying less these days.
Mike Stafford
Yes, I am proud to say I have lost over 40 pounds as of this morning when I weighed at the gym.
(I will not be mistaken for Jack Sprat any time soon however. :\ )
fantastic
Have you seen the new movie Grudge Match. That's what I'm training for. :) Very funny movie.
Dale Cook
You could use the after market heated hand-grips that are for snowmobiles and atv's. I was just going to order them for my atv as I have a plow on it. A friend of mine that I've fished with in Canada in the late fall put them on his fishing rod and it really worked well.
