A VFD question!
A VFD question!
A VFD question!
Tom
It is getting colder here in NE Ohio and the cold weather seems to stimulate the little brains cells! So I have another question.
Saw a video over on Wood Forum about a fellow that took VFD and a used 3ph motor and set it up for variable speed for his drill press. It looked very straight forward. So I looked around on line and found a "package deal" for a 3/4hp 3ph motor and VFD for a bit under $200.
Would like to hear from someone who has done a conversion like this as I am not going to go the new lathe route at this time.
Thanks!
And stay warm!!
Re: A VFD question!
Re: A VFD question!
Josh bowman
I upgraded my 1950ish metal lathe with a 3/4 hp motor and Teco vfd. Not to hard at all. Works great.
Re: A VFD question!
Re: A VFD question!
I've upgraded 2 lathes this way. Not hard at all. Although there are a ton of parameters you can change on the VFD I left them pretty much as they came from the factory floor. I only played with the electronic braking and ramp up speeds to find a setting that more or less resembled what I thought a lathe should be.
the wiring is pretty straight forward.
Re: A VFD question!
A TECO
Tom
This is the brand VFD the fellow in the video used. Is it a good brand choice?
Re: A VFD question!
Re: A TECO
Can't say about brand quality for sure. The first one I did was a TECO and it's still working. I sold it to a friend and he's still using it. The second one was a brand I had never heard of. Got it on sale used. Can't remember the brand but it is still going good as well. Sold it to another guy who still owns it.
Re: A VFD question!
Re: A TECO
Tom
This the one that caught my eye.
http://dealerselectric.com/item.asp?cID=0&PID=6900
Or is 3/4 hp adequate?
Re: A VFD question!
Re: A TECO
Josh Bowman
Tom, That's the one I bought. A friend at SMC also bought one ahead of me. Like John Lucas said. I played a lot with the parameters (kind of like messing with a smart phone). Only one parameter really remained changed and that had to do with "slip". I found the factory setting kept the motor on speed (or frequency) and if it tried to slow down due to loading, it would shoot the current to the motor and the VFD would shutdown on over current. This only happened at real low speeds, like 50 rpm and really loaded. So I changed the parameter and that fixed the problem. As for a wood lathe, that should not be an issue, since at 50 rpm you aren't really going to load up the motor. If you get 220 volt or 120 volt, remember you only need heavy 12 or 14 gauge wires to the motor and the power cord. The "control" voltage for the on/off switch and potentiometer only needs to be some lite stuff, like phone wire, since it's only at about 24 volts and almost no current.
You need to pick up from Radio Shack 271-1715 10 ohm pot, and 275-0654 SPDT (single pole double throw) switch. At least that's what I used on my 1 HP TECO VFD.
Rule 1, these things were not made solely for wood lathe users. I'm thinking computer controlled widget makers in large factories. That's why they have so many options.
Rule 2, hook the power and motor up and run it without any other external controls. You can raise and lower speed and turn it on and off with the control VFD box.
Rule 3, change and record the change of any parameter, so you can put it back.
Rule 4, when you're ready to hook up the external controls, do one at a time (on/off switch or pot) and test it. Also ask and I'll send you some pictures. Or go to SMC and search for Monster Lathe Update thread. David, had a bad motor that he got a a flea market and that caused a lot of problems. If you get this rig from Dealers Electric, you'll have little problem. BTW the motor you get is NOT like wired to the VFD. It's not hard, but those wire numbers were real hard to read. You might want to borrow a kid with good eyes to read them for you!
All in all you'll love it. The unit takes my old metal lathe up and down as smooth as silk. After I got over playing with the options and just started using it, I find it to be very reliable. I feel it's some smoother than my Delta VFD on my PM3520b.
Re: A VFD question!
Re: A VFD question! *LINK*
Dick Coers
These guys make it sound like a breeze. Be aware that the instruction manuals are not written for hobbyists and for those with no electrical knowledge. Also be aware that you need all the switches, and a potentiometer, and then wired correctly to all the terminals. Here's a link to read some real nice basic info. David had a lot of trouble with his first fore into using a VFD. He wrote this as a VFDs for dummies. If you search for his other posts, you will see that it's far from plug and play!
http://www.sawmillcreek.org/showthread.php?209105-FM50-Wiring-for-Dummies-(A-tome)&p=2168844&highlight=#post2168844
Re: A VFD question!
Re: A VFD question!
Bill Howatt
I agree. If you don/t have some clue about electricity, electronics and the like, the user manual will be an absolute mystery. If you are careful, have a wiring diagram for what you want to do and take "the defaults" it will probably work. If you want to optimize the operation, then it gets very complicated very quickly.
Bill
Re: A VFD question!
I believe it is a 10K ohm pot, not 10 ohm
Re: A VFD question!
Re: I believe it is a 10K ohm pot, not 10 ohm
Josh bowman
Agree. I do know the Radio Shack part # is correct.
Re: A VFD question!
Re: A VFD question!
steve worcester
depending on the lathe, that might be underpowered.
What is the lathe, swing?
Re: A VFD question!
Re: A VFD question!
Tom
Dick,
Thanks for the info and link. I am guessing that the pot is used as a more convenient way to adjust the speed than holding the button.
Would you have any pics showing the "dust" enclosure for the VFD?
Thanks
Re: A VFD question!
Brad Vietje
Re: A VFD question!
Brad Vietje
I did this about 10 years ago with a 1.5 HP motor on an older style Nova 3000 lathe. Worked slick as a trout -- variable speed and reverse, with 8 different speed/torque ranges (most of which which you will never need). Can't remember the vendor, but I bought the 3 PH motor and controller from an outfit in New York City.
Safe spinning,
Brad Vietje
Newbury, VT
Re: A VFD question!
Re: A VFD question!
Bill Howatt
I'm sure there will be various opinions, but turning a pot is a lot more convenient than holding buttons IMO.
Can't tell you much about the dust enclosure specifically but on my General it is a large metal box that is probably around 4X the volume of the VFD unit. There are no obvious vents which surprised me but I guess they are going for dust exclusion. I don't know if the unit gets some heat-sinking benefit by by being fastened to the lathe pedestal.
If you connect a pot and have it at a remote (from the VFD) location for convenience, consider putting the VFD's operating on/off control beside the pot to reduce the chance of turning on the lathe with the pot set to high-speed from the last operation. The pot knob should make its setting obvious, that is, have a pointer or a number scale on it. You can also include the forward/reverse control for the same reason but it is less of a hazard. Reverse, if you aren't aware, can be useful for sanding since the wood fibers tend to lay down when sanded in one direction. Reversing allows the sandpaper to "catch" the fibers on the next pass.
Bill
