OK I'm confused
OK I'm confused
OK I'm confused
The thermometer in my shop says 50. No way. my hands get freezing cold in minutes. I've worked outside in 50 degree temperatures all the time with no problem. Can't figure out why the shop feels so cold. The thermometer is 10 feet from the heater. I'm much closer than that when I'm at my table saw, workbench or lathe.
I'm starting to think I need a heater attached to one of those walk around thingies they use in the hospital to hold your IV's. Hey maybe a better thought might simply be a Jack Daniels IV. :)
It's 6 degrees outside which is really cold for Tennessee. You guys up north can have it. :)
Re: OK I'm confused
Us guys up north
Terry Quiram
don't want it! Its -14 this morning. Glad I am retired. I am not even walking across the yard to the shop today.
Menards sells a glove that I use when weeding the garden. It is very thin, form fitting and the palm is coated with a rubber membrane. No reason you couldn't turn while wearing them.
Re: OK I'm confused
Dear Confused:
I am near Richmond, VA and it 54* OUTSIDE. Raining. They (The weather guessers) tell us it will be about 10* tomorrow. You are scaring me to death. Go outside and inhale. A lot. You and anyone else can keep it. When you exhale, blow to the west. God Help the plumbing around here.
I bet your equipment is a lot colder than fifty. YOU are suffering from radiant losses. Heat radiates from the warmer body to the colder surface at some rate that is governed by the temperature differential to the fourth power. My shop warms up abut the time I am ready to leave.
Re: OK I'm confused
Alan Zenreich
Re: OK I'm confused
Alan Zenreich
Two things...
1 - Move the thermometer to where you work... no sense in knowing the temperature of someplace you're "not"
2 - Get another thermometer to confirm the reading (and also become confused... the old saying is "A man with a watch always knows what time it is, a man with two watches is never sure"
This won't make you warmer, but it might help explain why you feel colder than the current thermometer indicates.
Re: OK I'm confused
Rob Wallace
Unfortunately, it's coming John....
Rob Wallace
I just listened to the weather report for today here in central Iowa.... she said "...today it will not feel any warmer than -20*F" - today's high is forecast at -6*F. Our overnight temperature was -21*F with a -41*F Wind Chill. And we're not the worst - I don't know how those folks in Minnesota and Canada deal with this "normal" kind of thermal abuse every year. Winds here are from the west-north-west so it's on its way to you John! Get done what you need to do today, because in another day or two it'll really be unbearable. (This is one of the few times of the year when I am thankful for a basement shop.)
STAY WARM EVERYBODY!!!
Rob
Re: OK I'm confused
Re: OK I'm confused
Cyril Griesbach
17 below here and the wind is gusting over 30 MPH so I'm unable to feel too sorry for you, John.
Re: OK I'm confused
What you are doing, possibly
Bill Howatt
The problem might be your level of physical activity. If you are expending more physical effort you will be warmer but if you are just puttering around your internal furnace and circulation aren't doing much. When you were working outside you may have been working harder or moving a lot more.
Us guys up north dress appropriately and to a certain extent get acclimatized to the cold. When we are complaining about how cold it feels in the beginning of December, the same temperature at the end of January would be "warm". Of course the cold gives us something to complain about and we are good at it.
When the hurricanes and tornadoes are wreaking havoc in the warmer months we often say, "Give us the cold anytime".
Re: OK I'm confused
Re: OK I'm confused
clay foster
We've got 10" of snow and minus 13 degrees here in Broad Ripple IN. The news people keep saying to check on the elderly people in your neighborhood to make sure they are okay. I hope I don't get a bunch of phone calls.
Re: OK I'm confused
Re: Unfortunately, it's coming John....
Rob I know how the guys in Minnesota deal with it. I called Mike Hunter to ask and he is in Hot Springs for the winter. That's how they deal with it. :)
Re: OK I'm confused
Re: Dear Confused:
Barry I had the heater on in the shop all night so you would think the equipment would be at the same temperature but you are right, the metal feels quite cold.
Re: OK I'm confused
Dick Hines
Re: OK I'm confused
Dick Hines
50 inside a in closed building will feel a lot colder than 50 out side.
Re: OK I'm confused
I'm sure Jen checks on you frequently
Re: OK I'm confused
Re: I'm sure Jen checks on you frequently
phillip Medghalchi
John, go hug one of your favorite bowls or turned articles you made and it make you warm and fuzzy inside. That may work and won't cost you a lot either.
Re: OK I'm confused
Re: OK I'm confused
Emmett Manley, Lakeland, TN
John, the difference in how 50 degrees feels to you inside your shop versus outside is probably explained both by your level of physical activity AND the presence of sunshine.
When he sun is shining on your sweater or coat on a cold day, place a thermometer on your garment and you will be surprised at how warm it will be. Air temperature is just that -- air temperature. You are concerned about your temperature.
Also, as others have pointed out, it takes a long time for warm air to warm up the mass of metal and wood in a shop. A cubic foot of air does not have much heat capacity -- a cubic foot of cast iron stores a lot of heat.
Re: OK I'm confused
Mammalian Dive Reflex
charlie belden
A vestige of our evolutionarty ancesters, we inherited what's known as The Mammalan Dive Reflex. If we touch something cold, like the metal on a gouge, the head or tail stock handle, a metal tool rest, it can trigger this response. Basically the body thinks it's about to get much colder and pulls much of your blood and heat in towards your vital organs (you decide which organ or organs are vital) - drawing it away from your extremities. And the body has a priority system - ears, nose, lips, fingers and toes the first to be sacrificed if necessary. Once the reflex is triggered and blood - and heat - are withdrawn from the extremities - they get colder.
Re: OK I'm confused
Brad Vietje
Re: OK I'm confused
Brad Vietje
Stay indoors, and stay warm, John!
It's an absolute rarity, but you've been colder than we are up in Vermont! We've already had a few -20F mornings, and a few days recently with a high temp of -3, but last night we got a ton of rain, and it was way up in the 30's today... Lost about a foot of snow on the ground that melted from all the rain and warmth. Driveway and dirt roads are sheets of ice -- not fun.
Tonight we're headed back below zero, and a high of about 5-6 degrees tomorrow, and windy. These are the times I'm glad I live in a straw bale house with walls that are 16" thick! No heated shop though :\
Can't say we like it up North, either, but we're generally used to it, and have insulated pipes and all to handle it. Good luck to all those suffering through this cold snap.
Safe spinning,
Brad Vietje
Newbury, VT
Re: OK I'm confused
Bill Blasic
Re: OK I'm confused
Bill Blasic
What is really neat about this latest weather is that every state had freezing temps except Hawaii - 49 out of 50! Now I'm sure that doesn't happen every day. Hit -10 here last night -8 right now.
Bill
