A55 Smoothing Plane
preserving the original color of wood
phillip Medghalchi
Bellow you will see the pictures of a new Mexico Juniper(Aromatic red Cedar) bowl. I tried to preserve the color and even though that i have put severl coats of Laqer Sanding Sealer on the outside it's still changing form porpulish pink color to a brwon hue. Outside already has 4 coats of the Laquer sanind sealer and It was applied between Mon. 12/30/13 and in between it was wet sanded with 400 grit sand paper and mineral spirit. then wiped and cleaned with denatured Alcolhol beofer the next coat was appllied. Outside is ready to take lacquer finish and tonight I manged to smmothe out the inside and get it very smoothe and applied a a good layer of lacquer sanding sealer on it. so the color inside is darker because it was done tonight and outside is already changing form the dark pinkish purple color.
Qsn. here is that is there any ohter ways to prevent this wood or box Elder form changing color? I s it possible that the chemicals in the Lacqer sanding sealer, denatured alcolhol or laquer thiner which I used to clean the piece before sealing it is reacting with the elments forming the actual colors in this wood?any healp would be greatly appreciated. Please bear in mind that i have not put any laqcuer finish on the piece yet. I am waitning for the tips before I proceed to finialsing the piece. and the pic.s are for this qsn. only the foot needs to be refined and removed so please do not comment on the piece yet. Thank you in advance.
Re: preserving the original color of wood
phillip Medghalchi
I forgot to mention that when i first started to put laqcuer sanding sealer on this piece the color was as pinkish as you see inside the bowl so we can conclude that within two weeks it's already changing and my goal is to prevent this form happening again. And, possibly try to bring back the color on the oustside too before finialising this piece.
The color on the outside and inside are true and no photoshop was used here. Just croped it so we don't have to be distracted by other objects in the pic. backgrounds.
I just remembered reading somewhere that someone had the same problem with box elder and he used soem liquified UV protection on his piece and he had success, however, I can not find that article anymore, nor do I remeber where in the world I saw it. I think getting old doesn't help here.
dougturner
UV light causes the color change. I have been successful using "Bullfrog sun blocker wax spf 30"some years ago. Some Varnishes have UV blockers, but I don't believe most lacquers contain any since lacquer is an interior only finish.
If you sand below the the current finish to bare wood and keep sanding below the sun damage you may get down to the original pinkish color and then apply uv blocker immediately to preserve the color. There are several woods that change color with exposure to UV such as pink ivory, purple heart etc.
Bill Blasic
Bill Blasic
Phillip,
As far as Box Elder goes I have pieces that while not in direct sunlight have not lost their reds. But now to be sure the Box Elder pieces stay vivid I dye the red with red dye. I use Transtint dye and dilute it to get the various hues. I don't know if that would work with your cedar but you could try on scraps to see.
Bill
I played with cedar a bunch of years ago and could not figure a way to keep the bright pink it is when first turned. Every finish i tried darkened it. I dismally decided to bleach it hoping if it got lighter whr I put finish on it the color would only darken to what I wanted. The bowl blew up. Apparently the bleach penetrated so rapidly that part of the bowl expanded ands and it just fell apart in about 10 pieces.
I've also experimented at length with ugh. Inhibitors. Nothing I tried would prevent the wood from changing color if left I direct sunlight
Keep it in a drawer, but even then...
Dick Coers
cedar will change.
Re: Keep it in a drawer, but even then...
Jim Breeden
Phillip, Same thing happened to me. It was a disappointment, but I have learned (?) :b to accept it.
Sergio
Nature and her elements cannot be stopped so easily.
Alan Sweet
Alan Sweet
I really like the pinkish color that cedar has after it has been freshly cut. After failing many times to preserve the color, I have come to the conclusion that it will be an experience that woodworkers will have and not be able to share. Cedar just gets darker with age. It does develop a beautiful patina over the years, but the pinkish color is lost to all except your memory. Enjoy it, you a one of the select few that will ever see it.
Love that thought Alan
Bill Nixon
I have heard that Armorall Protectant (Original) works. It was applied and allowed to dry overnight before the finish was applied. I have not used it but would like to hear if anyone has.
phillip Medghalchi
Well, folks, let's see. I forgot soemthing here. While I was hollowing the bowl recently I have been trying to figure out that how I can save soemm of the core of the wood I am working on for bowls instead of just making chips and shavings. So, result is that I am managing to save small pieces to have a surprise for the recipient of the bowl. Anyways, I managed to save a piece in this case that I immediatly sanded and this time thought since it wa samll enough let's try to finish it wtih Myland's Friction polish. So that was on Mon.12/13/13 and here it is on 1/6/14 The color stayed the same and will report as the days wear out and we will se what happens. BTW, this little piece was sitting under the afternoon sun on our dining room table for few days. remember that I live in San Antonio, TX that has very bright sun when it is out. So, sofar so good. I am hoping that this may be the answer totry and preseve the original color of the wood.
Also, I thought that there was a mamber hee who is a professor in
botony and a wood turner who may be able to answer us as what is in the chemichal make up of these pink Hued woods that the chemical make up of the lacquer or the sealer will react to it. I am thinking that there should be something chemically that happens here if we try not to bring them to gether, then we may be doing soemthing goog.
Ok, this is how the little piece looks like with the Friction polish and this is the bowl today color is changing already.
phillip Medghalchi
Bill, my dilema is that I don't have any of this wood left and I can not bother my neihgor's Dad for soem more of it at this time they are dealing with some major health isuues with the family. i am hoping that next time he comes this way I can ask himm to bring me soem more to try to experiment with it. he turned bunch of bowls form this wood and they are all brownish in color. My wife is in love with purple and i thought i try to make her something with this wood. Unless,i amm chasing my tail hre and don't want to admit it. :(
Armour all will not work
I tried Armour all along with several other " industrial" UV protectors. They all work to some degree, better than no finish at all but none of them worked to keep the color in Box Elder for more than 2 days when subjected to direct sunlight for however long the days were at the time, probably 14 hours or so.
All seemed to fade about as fast. The only one that stood out from the crowd was Spar Varnish but it's so Orange in color who would ever use it for turnings or furniture. Boats maybe.
Re: Armour all will not work
phillip Medghalchi
John, someone mentioned that to me and I was not aware of it's yellow coloring, Thnks for the warning.
Brad Vietje
Binh Pho Uses an Air Brush
Brad Vietje
Just an "Oh, By the Way, Phillip"...
Brad Vietje
That's a bowl with really pretty colors, but you are turning end grain, right on the pith (which I do all the time, though it is an extra challenge), and you've got two radial checks here, at least one of which goes all the way to ground zero, with the other one not too far behind...
And, Red Cedar is a pretty weak -- even if fairly light -- wood...
SO, what really I mean to say is... "Be careful, buddy!" We wouldn't want to read about you in the next report of the woodturner who was whacked in the face or lost an eye at the lathe, now would we? Great color or not, if it's going to fall apart, and you haven't stabilized it FOR. REAL. with West System epoxy or something like it, you may want to watch the pretty colors as it burns in the fireplace with both eyes ;)
Safe spinning,
Brad Vietje
Newbury, VT
Re: Binh Pho Uses an Air Brush
phillip Medghalchi
Brad your losing me buddy. I am not following.
Bill Howatt
I believe he goes over the colored area with an airbrush and paint or dye. He isn't alone and some also use things like colored markers, or as they say, whatever it takes.
Bill
Brad Vietje
Brad Vietje
Yes.
He reinforces the colors that are there with permanent inks and/or dyes, and probably adds color to pieces that never had any before, and his red streaks do not fade.
Safe spinning,
Brad Vietje
Newbury, VT
phillip medghalchi
Well, remember this post?
Tonight I was on the site and looking at some of the posts then I can't remeber how I got to this post however, I found this in the archives.
Subject: Re: What I do with Redwood and Western Red Cedar *PIC*
Posted By: Russ Fairfield
Date: 2/11/2005, 8:15 am
Response To: Finishing Help on Redwood Burl Bowl *PIC* (Mike Sloan)
Here is the qsn., this article was posted in 2005, and we have had almost 9 yrs of technological advancments in paint industry, so is this still a good way of trying out my hands on the next piece?
The other thing is that the pic. is no longer available or wouldn't load up.
