What to do now?
What to do now?
George Balock
What to do now?
George Balock
There was an article in the local paper on New Year's Day regarding the demise of the incandescent light bulb. I didn't think much about this until I started to think about loading my bowl kiln. What will be my heat source once incandescent bulbs are no longer available? My best guess would be a halogen bulb. Any thoughts?
Re: What to do now?
Re: What to do now?
Dale Gillaspy
My first thought is to vote ANY incumbents out of office, but that could lead us down a whole path we shouldn't go down here. I would stock up on several. Whatever has been made can still be sold. They can even still be manufactured, they just can't be transported across state lines, so that limits things quite a bit. Like I said, I would stock up on as many as you can find. That should last you several years. After that, halogen might be an option, but I have a feeling they may be on the short list, as well.
Re: What to do now?
Re: What to do now?
Scott in Falcon
Incandescent heat lamps (the kinds used in chicken coops and to keep food of questionable age warm in some fast food places) are exempt from the ban. I think that your kiln will be fine for some time to come.
Re: What to do now?
Don't lament the demise of .........
JamieDonaldson
...incandescent bulbs, because there are many good alternatives for this application. Q/Halogen bulbs as example are more energy efficient than incandescent, and put out plenty of heat. No problem! ;)
Re: What to do now?
Re: What to do now?
james jacomb
Have you ever put your hand under an LED bulb, not cool, also check out gardening supply, and farm supply catalogs for heat lamp bulbs or maybe you have ag stores local
Re: What to do now?
Re: What to do now?
I'm not happy about it either. I use 60 watt bulbs to heat my chemical and paint storage cabinet don't want to use heating elements or quartz lamps in that application. Too much fire hazard I purchased a bunch of them but they don't last long.
Re: What to do now?
Re: What to do now?
John Jordan
Watts=watts, and watts = heat, no matter what kind of bulb, or heat element etc. 10 watts is the same amount of heat no matter what produces it.
There are NO laws regarding transporting bulbs across state lines, (really).
If you need incandescent bulbs, go buy $100 worth=probably last most people a lifetime. For your kiln, buy a heat tape-the wood doesn't care.
John
Re: What to do now?
Re: What to do now?
Dale Bonertz
I agree John the wood could care less. When I built my kiln I mounted a oven heating element in an old metal desk top computer case. Blow a fan across the heat to disperse. Put a thermostat on it and it will shut off at the temp you want. Heating element $15 - thermostat (I bought a commercial one) $can't recall. Cut kiln operating cost in half from using three 100 watt bulbs in old kilns.
Re: What to do now?
Re: What to do now?
Terry Scott
Buy a bulk lot they wont go rotten
Re: What to do now?
Jim Evans
Re: What to do now? *LINK*
Jim Evans
Come on folks, pay attention there are a lot of loopholes in the law.
If you want incandescent bulbs follow the link.
Incandescent bulbs
Re: What to do now?
Re: What to do now?
Charles Drake
Rough service bulbs and appliance bulbs not included in ban-big box stores and Amazon have lots available.
Re: What to do now?
Brad Vietje
Re: What to do now?
Brad Vietje
Also, the heavy-duty bulbs for inside your oven (in the kitchen) are still available, and might be the best choice, anyway.
Incandescent bulbs only emit ~5% of their output in visual wavelengths (a.k.a. "light"), and the other 95% is infrared (a.k.a. "heat"), so while they are a terrible source of light, they are very efficient little heaters ! 8)
Halogen bulbs put out a little more light/watt, but they are also a terribly inefficient light source, so they are good heaters, too, just more fragile -- at least in my hands.
Great idea about resistance heat tapes, John! I suppose if you want real efficiency, rig up a little air-source heat pump, and away you go!
Safe spinning,
Brad Vietje
Newbury, VT
