Worth Considering?
Tom
A Rockwell 46-525 lathe with a mechanical speed change. The guy is asking $450.
Worth Considering?
Tom
Re: Worth Considering?
Ralph Lindberg
More then I would pay
Jim Breeden
By mechanical, I understand it to be Reeves drive ?
Rob Wallace
This Delta is a bit on the "old" side... but from the day of "real" cast iron.
I agree with Ralph, a bit too high a price for a lathe of that vintage - If you think you want it, offer $ 300 and if necessary, come up to $ 350. You can get a new 6-speed Jet 12" lathe for not much more than $450, without worries of having to upgrade or restore something with older parts (although this lathe was very common in its day; there are many parts listed periodically for the 525 that are still available on sites like eBay - I restored a headstock of a 525 and now use it as a separate 1" x 8 tpi "spindle" for sanding and buffing). Make sure all the parts are there, look for cracks in castings of headstock, tailstock, and banjo (as well as the ways), and check the motor carefully if you DO buy it! Older parts can be pricey if you need to replace them.
(Watch "Pawn Stars" for haggling practice if necessary...!!)
Rob
I agree with Rob. If he is selling some tools, chucks etc at that price then it isn't bad. Don't think the lathe is worth over 350 by itself
walta
I love old tools but most old lathes have a 12 inch swing or less.
Most turners today want turn bowls a 12 inch swing is to limiting.
I am sure this would be a fine lathe if you want to be a spindle turner.
450 is a lot unless it has had all the bearing replaced and every part has been restored to a like new condition.
Walta
Depends what you want to turn
Dick Coers
Spindle work, pens, pepper mills, really small bowls and it's worth considering. It does not have a low enough speed for bowls that will max is out. Pretty poor lathe compared to what is out there these days.
Don in Central Illinois
I only paid a litgle over 300 a vew years ago. It worked fine, but I wanted/needed to turn larger than 10". I k ow it says 12" but with the banjo i the way, it wss very difficult to get a true 12" vessel.
Tom
Thanks for the replies and the insights.
arthur mcviccar
I had one, loved being able to turn on the backside because of the slim profile. But boy was it noisy.
