Big Bowl to end the year.
david
Probably my last bowl of the year, and it is the largest diameter I have attempted. The wood is Cook Island Pine, and the diameter is 21-1/2". The log was 23" x 27" oval, and had to cut it round to fit on my Vicmarc. Used a chain saw with angled cuts to reduce the weight. This piece is rough turned with no sanding as yet
, but because it is wet and thin enough you can see the translucence with a light behind the piece. Walls are just over 1/8" and about 3/16" at the bottom. Keith Thompkins' Gage'T was invaluable in measuring wall thickness past the reach of my fingers. This basically a regular bowl shape with a slightly flared lip and a thickened edge with a slightly undercut rim. Will wait a few days for the tenon area to dry more and stiffen up before I reverse chuck it and turn away the tenon. The translucence will go away when the wood dries, but should return after multiple soaks in the oil mix. Fortunately I have a large enough barrel to soak this piece.
I'm just sayin, be careful. Late in the game to ruin it now. Don't do what I have done and get Cavalier. Looking forward to seeing the finished product.
