are you looking for. A good light and inexpensive electric close quarter drill is on sale at Harbor Freight for $29.00 or so. They work well and cheap enough its a throw away after two or three years (the length that mine are now in). If you mean air driven there are several out there but require a lot of CFM and are generally noisy.
have you lloked into the Sioux or Milwaukee angle drills? I know Klingspor among others, carries them. Do a Google search for angle drills. Makita also makes a right angle drill.
Check out Vince's Wooden Wonders (not sure that's right at all but he gets good reviews here.) So does Sanding Glove.
Also Check out Klingspor. A sponsor of this site.
And Industrial Abrasives.
I have been using a regular Dewalt drill. Have not adopted a right angle drill. It might be a wonderful thing. One of the drawbacks is that the bearings in these drills are not designed for the lateral pressure. They may fail prematurely. They are tedious to rebuild, but you can install significantly better bearings.
Several thoughts. Three inch disks have 2.25 time the surface area of 2" disks and last a lot longer.
Heat kills the pads. Sand with a light touch. And....I would like to have mandrels that have the hex shafts with the snap connectors on them, Then I would create a "set" with a mandrel for each grit. Then you could switch mandrels with each shift of grit, giving them plenty of time to cool off.
Power sanding is a good thing and once you get into it you will wonder why you did not start sooner.
I had a friend who did a lot of bowls and he was a fan of Milwaukee, or at least he was, according to him the newer models don't last any longer than cheapies for this application. There is likely some truth to the bearings not being designed for the lateral loads.
I bought a right-angle drill that may be equivalent or slightly better in quality to a HF but made in China, of course, and have been using it for years although I don't turn a lot of bowls.
My 2 cents worth....For all exterior and larger interiors I use a METABO random orbit. Cuts fast and leaves a minimum of swirl which is taken out by the next grit. For smaller interiors I use a random air sander (Artisan from Craft Supply) with a 2" pad. It runs well off a 4.5CFM compressor. Yes it is noisy but I use ear protection any way. Regarding the low end angle drills....I use them a lot for the final grits. All you have to do is blow them out periodically (half hour) when sanding so the dust doesn't get packed in the rear bearing area. They are drills, not sanders. If you are lucky they will last years.
I've been using the standard $60 Dewalt drills with great success for over 10 years. In fact the first held up so well I bought a back up at the Pawn shop so when the old one dies I will have a another one. The old one is still working. I've heard to many stories of the angle drills acting up so I guess I'll stick with these until they wear out.
Re: What is a good power sander for sanding ... *LINK*
Rob Wallace
Alan:
I have been using a "close quarters" drill from Milwaukee (Model 0375-6) for over 10 years, but take care of it by routinely blowing out the body and motor compartment frequently in use. This particular model is no longer available, but similar "clones" are around - some have already been mentioned. Another source is "The Sanding Glove" which also sells a less-expensive version of the close quarters drill. You may also find them listed as "angle-head" drills.
I would advise against buying a 'right angle' drill, since the 55-degree head offset of a close-quarters drill is actually a more ergonomic design. You will be holding this tool for long periods of time while sanding, and you want to minimize the operator fatigue as much as possible. Variable speed is also desirable when purchasing a drill for this purpose.
The drill itself is sold separately from the actual sanding components. The 2 inch and 3 inch hook-and-loop (~"Velcro"{tm}) disk holders are the most widely used sizes, and are purchased separately, as are the loop-backed abrasives. There are also interface pads which have firm, medium, or soft characteristics that are matched to the sanding task at hand.
There are still many of these kinds of drills available on the market in a range of prices. Some are considered 'investments' and other are considered "disposable" - it's your call on which perspective you intend to follow, but you will enjoy the speed and improved quality of surfaces obtained from power sanding. The #1 rule is to keep the sanding contact speed down (both from lathe rotation and drill rotation, as well as not pushing too hard. The more aggressive your sanding becomes, the shorter the life your abrasives will have, and the surface quality suffers.... take your time, keep the speed (and ultimately abrasive temperature) down, and the sanding efficiency will go up. Clean-off build-up on the abrasives often (crepe rubber cleaner or compressed air), and your abrasives will also last longer.
I used a higher pressure, maybe 90 lbs., when I blew out the dust on my Milwaukee right angle. Something blew loose and the drill wouldn't work. I ended up taking it a part and it worked fine with reassembled. I don't know what was loose but have since used lower pressure.l
Terry Daniels used to post about replacing the standard bearings with sealed bearings. Do a search and you might find some photos he posted a few years ago showing how to do the job.
I have 2 I've bought from Vince. I got them when he was at the Cincinnati Symposium. One's 2 years old still going strong the new one is still in the box waiting when and if it's needed. I think Vince's are about $ 65.00.
Whatever drill you use, the mostimportant 2 thigs are this: sand with a light touch and ... before you turn on the drill, blow out any dust that may have accumulated in the housing with some compressed air. I beleive that Sioux/Milwaukee are starting to include some sort of disclaiomer that says to do this or it voids the warranty. I have a Sioux that i have used extensivley and aggressively for over 10 years. Replaced the brushes once. I religiously blow it out. And, once or twice a year, I open the case and give it a thorough cleaning and onspection. Power sanding is yout friend.
I second the cheap Harbor Freight right angle drill for ~$29.
I bought a high quality Sioux right angle drill but stopped sanding with it several years ago because I just didn't want to kill it. It's a top quality drill and I find it useful for many other tasks in my shop and it will likely last for many years.
For bowl sanding, I bought a cheap right angle drill from Harbor Freight years ago and used it exclusively for bowl sanding - it held up for several years and ultimately stopped working. I turned around and bought another for $30 or so and it has been working well for a few years now.
Bowl sanding is just so hard on drills due to dust (unless you are very good at blowing them out regularly) that the disposable drills from Harbor Freight just seem like the perfect tool for the job.
