too rest shapes
too rest shapes
too rest shapes
Well we had fun talking about tool rest height, how about shape. I have 2 things I don't like. For turning platters I think it's important the the tool rest sticks out as far as the banjo. That's one thing I don't like about the round rests. If you move the banjo up to so the tool rest is close to the wood and you have a square platter the corners will hit the banjo. This is really important when I turn my one piece mirrors because that handle is spinning around and will easily hit the banjo if your tool rest isn't the first thing it can hit.
for that reason I think the old cast iron rests were tilted about 45 degrees and welded on so that the front edge extended slightly past the banjo. However I also use a pull cut when turning the back of a platter and that style rest makes the tool pivot on the lower edge if it's not really steep so the tool is extended way above the support. I had to grind the lower edge of the casting way back on my smaller Powermatic tool rest because it got in the way with many cuts.
the big Robust tool rests accomplish both because they stick out beyond the banjo and the lower portion is out of the way for most cuts.
I can't tell if the Sinner tool rests are slanted like this or stick straight up. Do they stick out beyond the banjo ?
Re: too rest shapes
Re: too rest shapes
Bill Howatt
Your point, or problem, is one I've certainly had with my General 260 and I imagine whether a slanted rest solves the problem depends on both the rest and the banjo.
My original slanted General rest was not the most proud point of the rest system. The General banjo has a 3/8" wall but then slightly below it is another protrusion of more than another 1/8" the locking screw is threaded into. This protrusion unfortunately is mirrored on the work side of the banjo.
Even my large Robust does not clear the banjo and I've certainly learned to give a couple of turns by hand before switching the lathe on. I imagine with something as delicate as your beautiful mirrors that even a careless hand-turn could do some damage.
Wonder how the Oneway banjos fare with this issue since you can buy them for other lathes.
Bill
