DVr 2024 ?
DVr 2024 ?
DVr 2024 ?
Terry Scott
Some time ago a thread was posted asking questions about the nova dvr 2024
Can someone point me to the link
I am doing an article on the virtues and the dislikes (no names will be mentioned )
If you can provide me with your findings Good or bad that would be appreciated.
Improvements e.t.c Value for your buck
Cheers Have a merry xmas
Terry
timberly@xtra.co.nz
Re: DVr 2024 ?
Re: DVr 2024 ?
Jeff Rich
While I have not turned on my DVR2024 a great amount, yet, I have found several things I like and dislike.
First, the dislike, on the tool rest.
The angle seems "wrong" for the way I turn.
The banjo also does not seem to lock in place all the time.
This may just be some trial and error adjusting I need to do, but the ways seems to not really have enough surface area for the banjo to rest on correctly.
The big positive is the smoothness of the motor and the ease at which I can do a 14" bowl core. Plenty of power and no slowing, stalling or stopping. I have turned a few scoops and really like the shorter bed for hollowing.
I am planning to give it a good workout this coming weekend and hollow a few birdhouse bodies and rough a few big bowls.
Re: DVr 2024 ?
Re: DVr 2024 ?
Terry Scott
Thanks Jeff
Have a great time over the break playing with your new toy
Love to hear how you get on
Cheers
Terry
Re: DVr 2024 ?
Re: DVr 2024 ?
JamieDonaldson
When I first saw these direct drive powerheads I was wondering about low speed torque and the longevity of the motors. Haven't heard much negative feedback about either?
Re: DVr 2024 ?
Re: DVr 2024 ?
Bill Howatt
That was the very reason I didn't buy the original DVR - it looked like a considerable expense if the motor/headstock failed.
I have seen very, very few, virtually zero, complaints about failures or power on the DVR line and there are enough DVRs around that any issues should be visible. There were some issues with the control boards at first but they didn't require changing the motor system.
BIll
Re: DVr 2024 ?
Re: DVr 2024 ?
Ralph Lindberg
Bill is correct, the DVR motor appears to have a very low failure rate. In our local club there are.....5? 7?, something like that. The only failures (two) have been in the board, and then only on the early models.
The Club's DVR has the least hours, and had a board failure. Mine is years newer, with many more hours (as in I leave the lathe powered for weeks at time), and no failures.
Re: DVr 2024 ?
Steve Kubien
Re: DVr 2024 ?
Steve Kubien
Jeff just nailed my only beef with its smaller cousin, the DVR XP...contact area between the bed and the banjo. I always felt the bed should be wider on the 16" version and I can only imagine this would be more true of the 20". Oh yeah, and the tool rest is horrible.
Power to spare and as smooth as my Stubby (the 16" version). Tempting to put that headstock on a custom bed.
Re: DVr 2024 ?
Bill Blasic
Re: DVr 2024 ?
Bill Blasic
Guess I'm opposite, never had a problem with width of the bed nor the tool rest. Been running for about 9 years now.
Re: DVr 2024 ?
Re: One sweet machine
Lou Krupnick
I've had the Nova DVR XP (16") for about 2-1/2 to 3 years now and not a hint of a problem. I suspect the gent with the banjo issue may not have it set up correctly. The machine is extremely well constructed;
most of my turning has been large bowls or platters & I frequently turn (dry) banks that range from 2-2 1/2" tk x 16-20" dia. outboard w/the head at right angles to the bed. It lives in a mostly unheated outdoor shed and it never complains about the temp even when it was 20 out this a.m. when I started turning.
Motor & controller is smooth and responsive, run out seems negligible. Only thing I miss is a better spindle lock. I cannot speak to the stand as I have mine mounted to a HF woodworking bench. At the end of the day, if my shop burned down tomorrow I wouldn't think twice about purchasing the 20" model, that is after the tears dried.
Re: DVr 2024 ?
Re: DVr 2024 ?
Geoff Whaling
Terry,
One issue you may consider in your article is that the DVR style, or any lathe with the motor mounted at the headstock, is not very friendly to turners who are battery operated i.e. have pacemakers or defibrillators (device).
The close proximity of the motor has potential for electromagnetic interference with the device/s. The device makers like St Jude, Medtronics etc generally recommend a 600mm (2') seperation of the device from from the electric motors on bench grinders, drill presses, table saws, lathes etc. Turners with pacemakers / defibrillators can still use these items with special considerations once their condition stabilises and their specialist gives them the clearance to.
Re: DVr 2024 ?
Jeff Rich
Dont get me wrong, I love this lathe! I agree that it is a sweet machine and especially so for the deep discount I got it (gotta love returns).
It seems that you have to REALLY crank down on the tool rest holder to get it to stay in place. I have talked to a couple of people that reported the same issue. I am going to check the flatness of the bottom in order to rule that out, just have not made the time. I am also wondering if it could be the clamp or something on the bottom.
By the way, keep an eye on the index pin. I had mine loosen up again.
It also works very well for coring, I was able to core a 14" walnut bowl in no time.
Re: DVr 2024 ?
Jeff. The nova locks have sort of a sweet spot for the adjustment of the nut that determines the position of the lock lever. Sometimes just a quarter turn puts the lever in position where it locks with less pressure
Re: DVr 2024 ?
Jim Breeden
Jeff, I had the same problem with mine. I tightened the end nut on the banjo shaft a bit and have not had a problem since.
Re: DVr 2024 ?
Lou Krupnick
Just take the banjo off & snug up the nut underneath & you'll love it
Re: DVr 2024 ?
Jeff Rich
I started another post called Problem Found!
I have a cracked tool slide lock cradle.
This why it goes cock-eyed sometimes.
