Tops and tools
steven antonucci
From left to right,
a metal rod with a hole in the end and a screw tapped to hold a bit of bandsaw blade ground to a half round profile,
a length of bow saw blade ground to the same profile with a slit cut into a stick and wrapped with cord,
a Sorby knurling wheel in a square steel bar with a slot ground into the end and a nylon bushing:
If you look closely, the first tool almost cuts a double pattern? The second tool tends to want to cut the single line. The knurling wheel wants to cut a spiral, but that effect can be varied by cutting left to right, and then back right to left. I am going to find some more wheels to play with other patterns, since the bar was 3' long and I still have 3 more tools' worth of steel left!
A loser look at the patterns:
I have a huge jump on the Toys for Tots event next year. Now, I just need to turn some for the two hospitals...
Steve
