Bottle Stopper Question
Tom
So today I saw some bottle stoppers and thought I should make them for some Christmas presents. My wife and I go to the Woodcraft store and after counting what I need I buy 15 bottoms for the stoppers. Now I have to turn the same number of tops!
As a REAL newbie turner, even though I have had my lathe for almost 35 years, I have not done too much turning.
So my question is what can I use for a finish? I was thinking shellac and wax?
So tomorrow and the next day I need to turn these out! Nothing like last minute inspiration.
Will appreciate you advice.
Thanks!
Re: Bottle Stopper Question
Not sure I would use shellac. It is alcohol soluble. If you get wine on the stopper it ruin the finish. I finished mine with rattle can lacquer. Wipe on urethane might be better.
Tom
I should have known better that to think shellac!
I like the idea of rattle can lacquer. I can turn them all, then spray them then buff them out.
William Duffield
I used to use walnut oil and shellac (Frog Polish), but some people aren't so careful as I am to not waste wine by spilling it on the stopper, so I usually use walnut oil and Johnson's wax, but it's not really as durable as I would like. Whatever you use for tool handles should work, e.g., WaterLox, but it requires three or four coasts over three or four days, and it's a bit too close to Christmas for a varnish to harden in time.
Jerry Louden
Jerry Louden
I use Maylans friction polish on my stoppers. It gives a quick hard finish that looks great. I know it is a shellac but I just dumped some wine on one of my stoppers and let it sit for a while and it did not seem to affect the finish at all.
Cyril Griesbach
Wipe on Poly and Beall buff for mine.
About buffing....
If you mean something like the Bealle buff or power buffing, you don't have time before Christmas. The finish must thoroughly cure and even lacquer won't cure that fast. Either use lacquer and don't power buff it or the friction polish mentioned below.
(Power buffing green or uncured lacquer results in a smeary mess. BTDT)
Re: About buffing....
I let the lacquer dry over night and don't have a problem buffing. I used to have problems when I used Deft but now I'm using commercial grade lacquer that I buy locally.
