I hate to clean my shop. I spend more time cleaning the shop vas filter than I do the shop floor.
The question is. I have a 3hp dust collector with a 6" port. I have a 4" pipe hooked to now for collecting sanding dust. I was wondering if I got a 2" adapter and ran a lint to the shop would it work to clean up the shavings?
I split the 4" line and added a 2" adapter but it does not seem to draw well. Would a dedicated line draw better. I will add a blast gate in the 4" line to close it off when the 2" is in use.
Dick, I have a smaller dust collector than yours and what I did was put a four inch line with about ten feet of flex hose on it that I move around to tools that are not permanently connected. (planer, dust pick up at the lathe, router table, whatever). Most of the major tools are permanently connected. Anyway, I have a piece of four inch S&D pipe that just slips onto the hose end. Its cut off as about a 45 on the business end and 3 to four feet long. I use it as a wand and use the DC as a giant shop vac. The size of the pipe makes it a bit awkward and I am thinking of adding handles to make it easier to hold onto.
I can't explain it properly, but shop vacs generate higher pressure (?) and more air flow through a smaller line. Dust collectors will move more volume through larger lines but do not do well with smaller lines.
If you have a cyclone I don't think this applies, but with my system its not always good to suck up long stringy lathe shavings. Some time they with get tangle up in the impeller. I solve that problem by letting dry out and walking on them for a few days. At least that's my excuse for letting them lay around and I'm sticking with it.
The four inch hose works great for general cleanup. One thing that is good is it does not have the tremendous suction to pick up metal parts. So, if you a little careful you do some gleaning. I occasionally find screws and small metal parts that I did not realize I had lost in the debris.
