good chatter work video *LINK*
I haven't used chatter blades as long and flexible as his. I'll have to try that. One thing I do differently is to tilt the blade left or right to create an even different look. I do like the idea of shaping the tip convex or concave. that has some interesting possiblities.
http://www.youtube.com/watch?v=3qWpqmBvprA
Re: good chatter work video *LINK*
Steven Antonucci
I don't see the need for more than one chatter?
Steven Antonucci
I have a small section of bow saw blade that is ground to a narrow 1/4" round profile. Like you, I will tilt left or right to change the pattern or vary the speed or distance.
I would think the flat ground end and flat presentation would tend to break fibers at the end of the pattern. Perhaps the evidence goes away when you cut you line detail in? I just use the point of a skew to do that.
If you have ever successfully colored and then cut chatter cleanly, I'd love to know how.
Steve
Steven Antonucci
i stand corrected
Steven Antonucci
Found another one I made a couple of years ago... looked pretty close, cuts a completely different pattern. Go figure
Steve
Hey I learn something new every day
Usually it's that I'm not as smart or good looking as I think I am. :)
Mike Stafford
Re: I don't see the need for more than one chatter
Mike Stafford
I have one commercially made chatter tool and a couple of others I made myself. Different shapes do result in different patterns on the wood but how much you project the blade and at what angle it is presented can also change the pattern.
Of course the speed of the wood also makes a difference. The hardest thing for me is to recreate a pattern that I particularly like on the next item I want to decorate. I guess I should write down the speed, overhang, angle etc.
George Taylor
Too much work to record it all ...
George Taylor
... it could get in the way of my FUN.
Steven Antonucci
one more factor
Steven Antonucci
My go to chatter tool is made from a bow saw blade. The one I found today is made from a piece of band saw blade. I have also use the disposable pull saw blades and a jigsaw blade. I make the profiles the same and they all cut different patterns. The band saw blades wear out fast, and the jigsaw blades tend to snap. The bow saw blade has lasted a very long time.
If I get a second, I'll post a picture of the two tools and the patterns they cut.
Re: one more factor
I bought one of the Bonnie Klein replacement blades and built my own handle. My other ones uses the hacksaw blades that they use to cut the metal 2x4's I find them at commercial construction sites. They just throw them down.
It's impossible to repeat the textures because even the wood changes how it works. There are to many variables. How springy the steel is. How far it's extended from the tool, how far the tool is extended over the rest. The speed of the lathe, how far you are from center, the angle of the tool and apparently the shape of the tool. OH yea and how hard you push the tool against the work.
dougturner
A couple of years ago I visited a wood turning school in japan and they have dozens of hook chatter tools. I saw a lidded bowl about 18" diameter that had chatter work in a band about 6 inches across. I watched a DVD of chattering technique with hook tools by one of the "national treasure artists" that was about 2 hours long which unfortunately was not for sale to the public which demonstrated fascinating chatter technique. This technique has been in use for centuries in japan and has developed much farther than in the west.
