Any updates opn the Hall Effect/strobe systems?
ron bauer
Is there any update from those fellows who were working on refining the strobe system that was brought up several weeks ago? I am very interested in what a good working system would look like. THanks for any additional system info you might have. Ron.
Re: Any updates opn the Hall Effect/strobe systems?
Rob Wallace
Rob Wallace
Ron:
I intend to work on my strobe system next week (....after my semester grades are submitted.......I'm still grading right now... :( ), and will be working on an NPN bipolar transistor switch to be able to drive the strobe with enough current in the voltage pulse to trigger the strobe's firing threshold, using the Hall-effect transistor I have. I still have to work out which switching transistor device to use and the value of the current-limiting part of the circuit (base current) to make a stable and current-friendly triggering circuit. I already had the Hall-effect transistor strapped to the lathe while firing its pulse into an oscilloscope, and the combination of magnet and sensor look good as far as tracking variable speeds. Once I get the trigger threshold circuit finished, I'll be in business and will post some results....
Rob
ron bauer
Rob, You lost me at NPN.....but I look forward to your results! Ron.
Josh Bowman brought his to our club meeting to show me how it worked. His worked great. He did however find out that at 3000 rpm the little rare earth magnet won't stick to the chuck anymore. :)
Josh Bowman
The hall effect works great as John said. And it's a great "gee-whiz" kind of gadget. Now for a practical use.....I'm not sure. The strobe really messes with my eyes! I can only use it for maybe 5 to 10 minutes. I still feel if you're turning something that is odd shaped or has bad tear out, the strobe might help. The set up is not too bad, although you have to mount the light to something.
ron bauer
New Post.Rob, as I was turning a square bowl (dish, platter) I got to thinking about how nice it would be to see the very tips of the wings. Then I remembered your posts on making a strobe. So......did you finish it and are you ready to share thoughts or hopefully a schematic. TIA, Ron
Rob Wallace
Rob Wallace
Hi Ron!
I almost missed this reply!
I did get my Hall Effect switch to work with the Chauvet Strobe light. Triggered by a 1/2" neodymium ("rare earth") magnet stuck to a Vicmarc VM-100 chuck, it triggered the strobe as desired, once I sent voltage directly to the Strobe's trigger, rather than relying only on the output of the Hall-Effect transistor. There was likely insufficient current coming out of the HE transistor to drive the trigger by itself, so I used a 2N3904 NPN transistor to switch the strobe trigger's ground on and off whenever a pulse was sent (to its base) from the HE transistor output. I now have to build an adjustable holder to position the sensor in the path of the magnet that can change the position of the sensor to phase the image of the piece being turned as it rotates.
The breadboarded test circuit worked very well after I added the transistor switch, so I am now building a final version in a chassis box with its own internal power supply, connections for a push-button on-off switch, and a connector to add a foot pedal switch. It took some time to scrounge-up the various parts to build the working circuit. This control box will be mounted to the wall behind the lathe, and the strobe will be mounted to a track above the lathe. The final version is not finished yet to be able to take photos, but I hope to spend some time this week (....it's SPRING BREAK!!!) to finish building the final version, as well as getting some turning done, between college visit trips with my son.
I will try to put together and post a circuit diagram, and provide some instructions on how to build the HE sensing and switching circuits. I'll see how this week goes and how far along I can get with completing this project (and a few others).
Rob
ron bauer
Rob, Thanks for the update. I am anxiously looking forward to your final version. I really appreciate your time in developing and posting your work. R.
josh bowman set his up
He brought it to our club meeting. I don't believe he had any extra circuitry. We did find out that the rare earth magnet won't stay on the chuck at really high rpm. You may have to add a little glue if you need to turn that high.
