Coring DVD
robo hippy
My sales on this DVD dropped to pretty much nothing, so I am putting it up on You Tube. Thanks to all who supported it.
http://www.youtube.com/watch?v=xk-Z-scS84w
robo hippy
Coring DVD
robo hippy
robo hippy
Re: Coring DVD
Sergio
Nice video indeed. i have only one problem with it, which is the problem I'm having with the McNaughton coring system: there is too little information on how to determine the angle of the cutter.
Re: Coring DVD
robo hippy
The bevel angle is around 70 degrees, which is common with scrapers. As for the sides of the cutter, if you keep the spear point, which I don't, they are about 45 degrees or so, or the 2 together make a 90 degree corner. Does that answer the question?
robo hippy
Thanks
Steve Mushinski
Robo,
Enjoyed your video and just wanted to thank you for posting.
Loved the out takes!
Steve
Lots of good "extras" in there!
Re: Coring DVD
Sergio
Thanks, but my problem is with the angle of entry of the tool, in other words the angle made by the handle and the face of the bowl.
Re: Coring DVD
Dale Bonertz
Sergio,
I did a demonstration on the McNaughton for our club in which they put up on youtube. Type in McNaughton Center Saver and it will come up under Rocky Mountain Woodturners or Dale Bonertz does a demonstration. I cover how to help you site the tool for angle of entry. I hope this isn't stealing Robo's thunder.
On a separate note to Robo. This video is much different than I remember the original video. Did you do significant editing? You no longer mention bending the tips of the blades in this one or I missed it.
Re: Coring DVD
robo hippy
Dale, this is the original. I didn't put the part in about bending the tips in a hair. That was some thing I discovered later. It always bothered me that the blades would always drift to the outside of the cut. The very last little bit of the blade pointing in a straight line seemed to be the answer. I can usually figure things out if I have enough time.
Sergio, Well, that angle thing is some thing that you have to figure out, and most of the time it is trial and error. Dale's video is good, and he uses a slightly different approach. The angle of the handle changes as you go in as the handle and tool move through an arc as you core. This changes a lot depending on the size and shape of what you are coring, and which blade you are using. The most simple answer I have come up with is that you want the tip of the blade pointing/aiming just slightly outside the center of the bowl bottom. This will usually get you there with a bit more thickness than you would want for a perfect Mike Mahoney 10 cores out of a tiny blank type of core. Safe. Do start with smaller blanks, maybe 10 to 12 inch diameter and 4 or 5 inches thick, and green wood. Repeat many times.....
robo hippy
Re: Coring DVD
Sergio
Thank you. The pointing to the left of center was in my mind.
Re: Coring DVD
barbara dill
I enjoyed the video and learned a lot. Thanks. I, too, was frustrated with understanding the angles but loved the results. The images I've posted show the way I found to know the angle of the tip and therefore, the handle. I wrote a paper that I'd be glad to share if anyone is interested.
Re: Coring DVD
Don in Central Illinois
I would love to have a copy of you paper. I judt bought one a few weeks sgo but havdn't had time to try it yet.
Re: Coring DVD
barbara dill
Glad to do it. Send me your email..Mine is bdill6@verizon.net
Re: Coring DVD
barbara dill
FYI, you can also find this paper on his website:
http://www.kelton.co.nz/guides_videos.html
Thanks for the Link Barbara!!!
Re: Thanks for the Link Barbara!!! NM
