Yarn Bowls
David Gilbert
There has been some discussion about yarn bowls so I thought that I should add my two cents. Below are a couple of photos of my most recent ones. The first is a Norway Maple crotch that was actually cut more like a short hollow form. The second is a spalted Paper Birch that was more conventionally turned. My daughter has an on-line knitting magazine where you can see more photos of the series we just put up (go to the shop page in Twistcollective.com).
All of my yarn bowls are calabash style and are about 4 inches tall and around 7 inches in diameter. The bowls are about 5/16 inches thick and a bit thicker on the bottom. Most are turned green to final thickness, dried, sanded and finished with Minwax Antique Oil. I cut the slot with a Japanese pull saw from Lee Valley and then carve and sand it smooth. I prefer to cut the slot after finishing but there are times when checks appear and provide "design opportunities" that I need to use to save the bowl.
Cheers,
David
