Does anyone know if
Alan Sweet
Titebond III has a shelf life? If so how much. I have a container that must be at least a year old. Is it any good?
Does anyone know if
Alan Sweet
Re: Does anyone know if
Harry Robibette
I believe Titebond III is like all the other Titebonds 1 year.
Guy Bratt
I would suggest go to the titebond web site and contact them. I did. They were quick to respond. They told me about shelf life, the number of freeze thaw cycles that were acceptable and also how to read their manufacture code/ date/ location code on the bottle.
Just buy some more its not that expensive and not worth ruining a project to find out. Or you could glue a couple of scraps together and the. Break them apart in about 2 hours and that should tell you
John Veerkamp
This has been a topic here several times in the past. The consensus seems to be that if storage conditions are OK (minimal freeze cycles) it will last fer several years. In my experience I've never had a glue failure using 3-4 yr old glue.
My take.
Titebond II does in the tropics
Geoff Whaling
Titebond II definitely does change in the tropics without freeze cycles. I purchase the 3.8l & usually use it within the year. Glue older than 18 months steadily changes viscosity and eventually becomes gluggy/lumpy.
I gave up using TB III & Selleys polyurethane glues for my laminated woodturnings as working with them was not so friendly to tooly & messy.
