I like the Micro tool quite a bit and use it often-but not on everything. I have not done anything large with it yet like a bowl rim. It take a little practice to get used to. Speed needs to be low-like 350-400 rpm and it needs to trail downward below center in my opinion. Make sure the wheel spins freely. Practice!!! I get fairly consistent results. I have only used the finer wheel so far. And be careful-the little brass screw can unscrew itself when using it in one direction.
I got the larger tool 2nd hand and have had limited success with it. I have tried many kinds of wood and have inconsistent results at best. I watched the Sorby videos as well. Cutter is sharp. Still little joy. I haven't given up but hesitate to try it on something nice still.
I have the small one. Lost the screw on the first day. apparently you have to use it so the wheel tightens the screw instead of loosens it. I made a bushing to go around the new screw I put in it and it stopped that problem. Other than that it's not a bad tool. Takes some practice like any tool. You have to play with angles to figure out what works. Use some scrap and just play. texture and then turn it away and texture some more. Won't take long to figure out a few things that work.
I also have the Sorby texturing spiraling tool. Use the texture a lot, don't use the spiral much. It works but leaves a rough surface because it's a scraper. It works well on really really hard woods like Osage Orange or Boxwood. Not so well on less hard. I do plan to work with it some more to learn to use it on softer woods just haven't taken the time to learn yet.
The micro tool is easier to use, but the details are quite small. It's my opinion it's easier to use because it does not have the chamfer on the cutter, and the square edge is sharper. The larger tool would definitely be more appropriate for large bowls.
Adrian, the December issue of American Woodturner has an article on spiraling and texturing. If you're not a member of the AAW and want to read the article, let me know and I will send you a PDF of it: editorscarpino@gmail.com
I have both sizes and both are usable. Each adds impressive detail to nearly everything. It may be as simple as highlighting my name on the bottom. You can't go wrong.
