Thinning Epoxy
Thinning Epoxy
Thinning Epoxy
Stuart Johnson
Can West System epoxy be thinned? I have a nice Mesquite blank I want to turning into a pepper mill but it has some thin wind shakes. I don't know if the regular mix with some black dye added will flow all the way down. Ideally it will go clear through to a sealed bottom.
Re: Thinning Epoxy
Re: Thinning Epoxy
Excellent read. Thanks chuck. I have used heat several times. I put the A and b in separate containers and heat them in water. I never measured but my guess would be about 120f. It gets quite thin at this temperature.
If I have it on hand I prefer to use system 3 Mirror coat from Woodcraft. It becomes very viscous when it is curing a d penetrates very deep. West system epoxy never gets that thin
Re: Thinning Epoxy
Re: Thinning Epoxy
Jeff Smith
Having made the mistake of finding myself the owner of an older Chris Craft that needed lots of TLC, I wound up with years of experience using West System epoxies on wood that had deteriorated from so many causes they can't all be listed. I found that viscosity can be misleading. That stuff will penetrate cracks quite thoroughly as long as you don't use too much hardener. A long cure time gives it plenty of time to penetrate the smallest of cracks. If your cracks completely penetrate the piece, either use some good tape at the exit point or use hot melt glue to form a plug there and start filling the crack from the other end - let gravity do it's thing, keep filling for as long as you can (until it gels) then let it cure. I generally have to mix a small batch as a second run once it has set and settled to the bottom.
Cover anything even remotely close with old newspapers, it's almost impossible to keep it corraled until it gels, and plan to cleanup the area around the entrance and exit points. You'll probably find exit points you didn't notice when you started. DAMHIK.
Re: Thinning Epoxy
Re: Thinning Epoxy
Stuart Johnson
The thinning article was very informative. It does sound like heat is the way to go.
Jeff, I have only mixed it using the recommended ratio. Will the hardening time and actual hardness be impacted if the amount of hardner is reduced?
Re: Thinning Epoxy
Re: Thinning Epoxy
Chuck Engstrom
I use a different System Three product, Clear Coat, for cracks, sometimes with coffee grounds added. It's pretty thin stuff to begin with and fairly slow to cure, so it seems to get in plenty deep even at ambient temperatures. I measure with a a 1cc hypodermic stuck in each bottle cap, without the needles, and have had no problems mixing as little as 0.4/0.2 -- this stuff is too expensive to waste as with West System can pumps.
I've seen Mirror Coat at Woodcraft but haven't tried it. Maybe when the Clear Coat runs out....
Re: Thinning Epoxy
Re: Thinning Epoxy
I've mixed epoxies by weight for years with great success. I use my old Photography digital scale. I seldom use the pump on my West System as I usually don't need that much epoxy. I pour (or pump) a little part A in a Dixie cup and weight it. Divide that by 5 or 3 depending on which hardener I'm using and then pump that amount in the part A. I have mixed very small amounts successfully. I always keep what's left over in the cup and check it for proper hardening so that I know what I used in my work has hardened properly.
Re: Thinning Epoxy
Re: Thinning Epoxy
Jeff Smith
Stuart: I'm not exactly a chemical engineer, but in practice the actual ratio of hardener to resin seems fairly flexible (within reason). A little less hardener may slow the rate of curing, but it doesn't seem to affect the rest of the properties. I doubt if you can take this too far before the cure time becomes problematic, but a little off in measurements didn't affect performance when I was using a lot of it. Just get it close...
If you're going to use heat to thin it out, I'd reduce the hardener slightly to compensate. Epoxy seems to be more sensitive to ambient temperature than having the ratios off a little. I'd also warm the wood rather than the epoxy - it seems to help draw the epoxy into the crack. If you heat the epoxy pot there's a chance you'll get the spitting, smoking pot that's kicked off too soon. You'll immediately know that you've gone too far. Use caution.
I usually build a dam around the crack with hot melt glue to form an area I can pour into and keep filling it up until the level stops dropping. Check the bottom end to make sure your plug or tape is holding. It can be a messy process...
Re: Thinning Epoxy
Re: Thinning Epoxy
Bill Jacksonville, NC
JMHO, find a better turning blank to work with.
If have the time & money could always try stabilizing your blank using either polyester resin, or Alumilite. Modified paint pressure/vacuum system at IAP library, casting thread. These two articles will get you set up & running. Do not know if can find info elsewhere online.
“Pressure/Vacuum Pot,” for casting blanks from or stabilize woods by Steve Swiger.
Curtis Seebeck A.K.A “MesquiteMan” provides a tutorial on “Worthless Wood Blanks.”
Is it easier to cast your blank in a mold using either PR or alumilite without pressure/vacuum? I disagree but can find instructions for that too in the library.
Re: Thinning Epoxy
barry rockwell
Re: Thinning Epoxy
barry rockwell
Stuart, having had an old wooden boat for 20 years before I ever took up woodturning, I have had many experiences with repairing wood with West Systems epoxy. Since I became a woodturner I have found it to be just as usefull in stabilizing wood for turning. I simply mix the West Systems with the proper amounts of resin/hardener, then dilute that mixture with an equal amount of MEK (methyl ethyl keytone) and it becomes thinner than water. Pour the resulting mixture over or into the piece repeatedly, using plastic jugs or buckets, until it won't absorb any more. Punky or cracked wood will suck it into the cells by capillary action and the result is a very stable piece of wood.
