Hollowing tool advice
ken chase
I do mostly hollow forms. Started with hand hollowers and ended up using a captured system.
Took a year off and now that I'm turning again I see there are a number of new tools using carbide
tips set at an angle. I bought one for my Jamieson rig and like it very much.
Now I'm thinking I'd like to try a hand held tool and the one I've seen in the catalog that peaks
my interest is the one offered by HollowPro tools. Any feedback about this or any of the others will be
appreciated. I note they have one for small hollow forms. I'm not sure what size a form is considered
large.
Thanks
Ken
Re: Hollowing tool advice
Re: Hollowing tool advice *LINK*
Dick Coers
You might want to look at Trent Bosch's new line of hollowers and hollower stabilizer. Looks good in video, haven't seen one in person. Most all his tools now have carbide options.
bosch assisted hollower
I was going to send you to Mike Hunters web site to look at his tools but apparently the domain is up for sale. Not sure what happened there. Will have to call mike and find out.
I have a set of the hollow pro tools and they are pretty good. However I find them a little grabby when used hand held. I prefer the more forward tilt of the Hunter Hercules but I don't know if Mike sells them in a longer bar for hand held hollowing. I use the small Hunter cutter in my Jamieson bar for a lot of hand held work. Since it takes a smaller bite than the larger cutters I find it more controllable when used hand held. It can also be swiveled in the bar to reach into more places.
ken chase
Thanks John:
Sorry I don't understand. When you use the Jamieson bar handheld do you mean the same bar
that attaches to the rig? The only reason I'm considering a hand operated tool is to
eliminate all the maneuvering I have to do using the rig when trying to work around the curve
where the top of the form flows to the sides.
Ken
ken chase
Thanks Dick:
Hadn't seen this before. Looks like a terrific product.
Ken
RCH
I just went to the Hunter site from the link listed here on the WC marketplace page. No problem -- the site came up immediately [ http://www.hunterwoodturningtool.com/ ]
Hunter tools are great for hollowing.
Yea. I just take the bar and mount it in either a Thompson handle or my home made arm brace. It won't reach around a sharp corner, especially with a small hole but will let me reach into a slopping side through a hole that's more like 1 1/2". for tighter holes and sharper corners I either use my John Jordan curved tool or the Hunter swan neck. The swan neck can be grabby if you cut in the wrong direction but works good when pulled toward you. I usually use that to clean up cuts rather than general hollowing. I like the controllability of the smaller cutters.
Fred Holder
I agree the Hunter Tools are excellent for hollowing. I first met Mike Hunter about six years ago at the Desert Woodturning Roundup and purchased one of the tools he had for sale. When I got home and tried it, I wrote a review on the tool and Mike said it helped him get going. Apparently, he got a number of orders shortly after my issue hit the streets. Since then I've tried a number of his tools. They have all performed well.
Ken chase
Thanks for the clarification. Appreciate the help.
Ken
Lyle Jamieson
Lyle Jamieson
Many of the tools mentioned use the new "nanograin" carbide from Mike Hunter. These are sharper and work better then the old carbide sold by some tool makers. Mike J. and Trent both use Mikes H. cutters. My system has no front end tilt so it can use bevel supported cuts. Some here have talked about grabbiness. The bevel is the answer to the grabbiness problem. The reach issue can be solved by using my bent swivel holder. I can get into a severe undercut shoulder through an inch mouth opening. In my opinion going back to hand held will result in the loss of control, loss of the laser assisted measuring, and will be harder on the body and wood and chucking method. Both hand held and captured can reach the same shapes. Is it OK to mention I cover advanced techniques like getting into small mouth openings in my newest in-depth hollowing DVD??
Re: Hunter Tools Is working *LINK*
Stuart Johnson
I just tried it and it worked. It looks like it has been updated.
Hunter Tool System
Craig Daymon
If you're happy with the rig you have, you can get a Hunter carbide tip that should fit your Jaimison rig. I bought one for use in my Jordon hollowers. I think you can get it from Craft Supplies.
-Craig
Lyle Jamieson
Lyle Jamieson
Craft Supplies are no longer handling the Jamieson hollowing system or my carbide attachments. I have them on my web site. Other carbide cutters will have different angles and will work differently compared to the Jamieson carbide system set-up.
