How do you turn a box and lid so that the lid will be tightly and properly held on top the box bottom? It does not necessarily need to be threaded but that seems the most appropriate.
For hand creating threads Google something like: thread chasing woodturning
Since the wood lathe doesn't have the controlled carriage for cutting like a metal lathe you can't make threads in such a controlled fashion.
Box lids are most often not threaded since the shoulders where you would cut threads tend to be very small. The lid is turned to fit the base with a snug fit. It cannot be too snug or the lid will not come off in times of high humidity when the wood swells.
For some types of lidded vessels it is possible to use mating threaded plumbing parts or any suitable mating threaded parts. The threaded portions get modified as desired and glued into the base and the lid.
Richard Raffan is the best source for all things turned boxes. Everyone teaches his techniques. He also has a method to turn a little raised area on the box tenon so the lid pops on. Lots online about threading.
Alan, I followed the directions from this utube video and bought a 16 then a 20 TPI from ashley iles. I've had little problem chasing threads with the unichaser. I made a rig that Mike Piece featured in a turning magazine, but prefer the had chasing. All it amounts to is a kind of rhythm. The hardest part is figuring out how much to turn the male and female parts too.
I can and do chase threads for boxes, but there is some cost and a learning curve. If you buy the tools, you need gooddense wood like boxwood or blackwood to turn the threads. if I am doing an urn, I usually by PVC or brass fittings and cut them to fit the base and lid. Brass turns easily on the lathe with a scraper, and looks nice in a high end piece. Craft Supplies also sells threaded brass rings.
You might want to check out Allen Batty ( Stuart's dad ) he is one of the premier hand threaders in the world. He has a really good DVD on threading and a hand booklet if I'm not mistaken. I have the chasers and all his info but no time to use it.
A snap fit lid is not hard to make you just need to sneak up on the fit. Richard Raffins book on boxes will tell you how
I thread boxes both hand chased and with threaders. Hand chasing tools run about $70 and do require a learning curve Threading machines run from about $250 to about $600. They do work well and are easy to use.
I use a good piece of steel, and prefer to cut my own threads, but you can use a bolt just as easily.
Take the bolt and cut it down the diameter and then grind the top flat to the middle diameter. The left side of the bolt is used to cut the female thread in a lid. The right side of the bolt is used to cut the male thread. You can see it in this video I made a couple of years back:
Steve, Thanks for the awesome video on threading. One question...what do you recommend for pitch, as a starting point? looks like your tool was around 16TPI. Thanks. Ron.
I have chasers from 12 to 36 tip. 16 and 20 are the most common for wood. Beginners need very hard woods to be successful. I learned using PVC pipe you can't make mating pieces due to the pipe sizes but you can practice inside and outside threads.
it is important to remember that not all woods are created equally. Some woods simply will not thread by this method. I think most woods will thread by mechanical means. As a result, just because you want a threaded pine box doesn't mean you can have a threaded pine box
I think that the tap I used was probably 1/2x "whatever" a common thread is? I used coarse threads because I assumed it would be easier to cut a coarse thread than a fine one. It was a guess. I also assumed that it would make the box easier to open if I didn't need to turn the lid 20x to open it.
As far as woods go, I know that I can thread maple in face grain and end grain orientation, oak in a pinch, pear and mountain mahogany. If I am working in some other woods, I will sometimes cut inserts from these woods if I intent to thread them.
On the lid, I turn a raised ring, which I grind most away, leaving 2 little tabs on the end-grain, so it will have strength.
Then in the top of the vessel, I only cut one keyway, which is off to one side of the grain alignment ideal position. The end with no key slot drops in by tilting the other end up while I slide that end in first.
I also, make a tiny incised mark on the outside of the vessel and lid, which have to be lined up, to be able to lift the tab out.
Over the years, I've done a great deal of thread making mostly with hand thread chasers, but some with commercially available threading rigs. If you are interested in the four page article that I use as a handout when demonstrating thread chasing, e-mail me and I'll send it to you.
