Turning Hemlock?
Turning Hemlock?
Turning Hemlock?
John McGaw
At 6:25 this morning, as I was trying to get my head operating, there was a huge crack and flash very close to the bedroom end of the house and the power went dead. A largish (maybe 16"-18" at the butt end) hemlock had fallen due to saturated soil and a weak root system; it went across the road immediately terminating all wired infrastructure to the neighborhood as well as snapping a utility pole like a stick. Nobody was hurt although it did cause problems for six hours as well as blocking the only road through the hood for even longer as the boom trucks from the cable and phone companies came in after the power utility finished.
If there is any use trying it, I've been considering taking my revenge by trying to turn a bit of the tree into some bowls. Have any of you played with hemlock on the lathe? Worth trying or should I just let the city haul it away when they get around to it? I used to be the adventurous sort of turner who would put anything from bones to antlers to stone to soft metal on the lathe just to see what would happen but my ambition has weakened over the years.
Re: Turning Hemlock?
Harry Robinette
Harry Robinette
I believe you'll find it very stringy but works well with very sharp tools. It cracks very easy so get it cut and sealed ASAP. I worked with some about 20 years ago in Roswell NM.
PAPA 211
Hey free wood is free wood, practice technics in bowl turning , use limbs for spindles . if you err it fit's in the fireplace nicely no big deal .Happy turning
Jim Sebring
Lots of resin in the stuff, but it burns real well in my shop stove.
Brad Vietje
Good For Timber Framing... Awful for Turning! *LINK*
Brad Vietje
This topic came up a few weeks ago, and I'll repeat my reply here.
Unless you are just doing spindles, it is awful for turning. Quite soft, and has a large difference in hardness between early and late seasonal growth, so sanding can create ribbed pieces with the darker lines standing proud. Could be interesting for thicker pieces that are sandblasted to accentuate these differences, but for bowls and faceplate work, I'd seek out a hardwood species over Hemlock any and every day of the week.
On the other hand, if you know someone with a portable band saw mill, you could saw it up and use the wood for projects like building a shed or chicken coop, or building a nice new work bench for your shop. Many timber framers around here use Hemlock almost exclusively, though I know one who only uses White Pine for scribed-log houses that are fantastic -- see Wooden House Company link.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Good For Timber Framing... Awful for Turning!
Donna Banfield
I agree with everything Brad had to say (been there/done that, and had the crappy bowls to show for it - long since burned now) but have this to add - hemlock is also great material if you do any chainsaw carving. If lasts for a long time outdoors, even without a spar varnish. If you lived closer, I'd get in my truck to beg some from you.
