Hollowing done with a 14" electric chainsaw, saw marks taken out with "kutz all" rolled edge disk in a Proxxon grinder. Willl use the Proxxon with sanding disks and then progably hand sand to 220, maybe 320 and then finish with platina or super blonde shellac - probably french polished.
I like the rough bumpy weathered outside surface juxtaposed to the s,ooth yellows, oranges and reds of the inside.
Nope - not when chainsawing. Sat it in redwood 4x4 saw buck and stood over it - wearing safety chaps (that used to be international orange, now more orangish) ear muff noise suppressors, turner's smock, closed up at the neck (I hate chips down my shirt - and into my shorts), safety glasses - and gloves (because it was cold (for California). For the Kutz-All work I held the piece between my "chapped" knees on the ground.
The guy who gave me this burl, who lives up in the Santa Cruz Mountains, says he's got a ravine full of them, and this was one of the "smaller" ones, He has another ravine full of redwood root burls and if I'm inerested, will bring me a couple to play with.
When folks know you're REALLY a Wood Phreak, they bring you stuff ; )
If this turns out the way I hope it will I just may have to look into getting a "carving" chainsaw. Anyone have any recomendations?
Nice piece. Being a flat work guy also, love the Chinese style table under it. Did you make that too? In the picture, it looks like it is in black and white. Photo shop?
I made the tables for diplaying bonsai. One of my sons got into bonsai and had some nice "trees" in nice bonsai pots - sitting on cinder blocks and plastic lawn chairs. I did six or seven of them - n different heights and widths so some of them could "nest" when not needed.
These were semi-quick and dirty - all redwood - some of which were old redwood fence boards and the legs are 2x2s with some beading using a "bead" router bit. The tops of the legs were rounded over partially with a 1" quarter round. They were sanded then given four or five coats of "danish oil". AFter sitting outside in the weather, such as we have in Northern California, they went grayish - as redwood tends to do - and smooth surfaces have weathered to a slight texture.
The joinery uses loose tenon - which I think I did with a DOMINO, maybe even with a router and mortising jig.
I made a masonite set of patterns for te "cloud lift" aprons, cut the pieces roughly to the pattern on a bandsaw then oscillating spindle sander sanded to the pattern pencil lines. Rounded over the outside bottom edges with a 1/2" quarter round just to soften the bottom of the "clouds". The cove molding under the table top was routed.
Nice looking tables Charlie. I had wondered if you tried to figure out the jigsaw puzzle methods that the Chinese and Japanese used to make those table leg and apron/stretchers join together. I remember a Fine Woodworking article in master class where they showed how to do it. Wild and Crazy.
