Why Upright? (and Stabile)
charlie belden
With bowls, plates, vases, hollow forms, lidded boxes, etc,there is an obvious Top and Bottom. The Bottom is, with the exception of "rockings bowls", flat - defining the horizontal plane and thus "what's up".
Then there's the Femisphere, which has no Up or Down, it's orientation AND location change if you touch it (or bump the surface it's on). Femispheres are inherently unstabile and tend to woddle around in somewhat unpredictable directions. Round bottomed pieces seldom will sit "upright" - usually coming to rest at their own balance point.
Now technically, Femispheres are NOT turned multi axis pieces since all the actual turing is done on only one axis, the turning split apart (on a "paper joint") - and one part rotated 90 degrees to the other on the flat faces.
True multi axis "spindle" forms almost always have at least one end of the blank left on the piece - to provide a foot for it to stand on. And that foot makes them stabile.
But - What If - you turned away "the foot" - and let the multi axis "sprindle turned" piece find it's own UP. - whch will probably be in some postion resting on its "side" - though multi axis pieces often don't have sides, but rather, they may have faces and edges. And because they have intersecting curves, once on their "side", they can roll in unpredictable ways, simiilar to how a Femisphere behaves.
Here's and example of an unstabile simple multi axis piece - two rounded bottom and top pestles (thing morter and pestle) - smooshed together - at a slight angle to each other. The form, on it's side would be very unstabile, rolling and rocking easily.
IF - it were placed in another inherinlty unstabile form - like a rocking bowl . . .
Lot's of interesting possibilities for Dynamic . Kinetci pieces.
Have YOU played with unstabile pieces or combinations of pieces?
If so, care to share what you found that was interesting?
