Got a fantastic deal on a use mini max 16" bandsaw. Barely used and I got it for about a third of what it sells for new. It's heavy, 485 lbs. Can't wait to use it. Gotta run a new 220 line and figure out how to put it where the older bandsaw was. fortunately the foot print is close to the same size so it won't take too much rearranging.
That is the same one I've got and had it for about 3 years or so, you are going to love it!
I hope you got the book with it as there are things that reading up on will help with it, there is no comparison with the Taiwan imports.
One thing is to make sure you level it as perfect as you can which isn't a problem with the leveling bolts that come with it. Once that is done you'll not believe there isn't any vibration when you lay you hand on the table.
You can now forget the "flutter" business and stop buying the silcone blades. In fact the carbon blades actually work better on this machine.
You can also call Mini in Texas and talk with a Mr. Blasko (cannot remember his first name) with any questions you have and he will give lots of help as he is a woodworker not just a sales person.
Check out there web site as it has lot of videos also
P.S. be sure and turn the machine off each time with the foot brake, don't use the stop button on the panel.
Is the motor a TEFC (Totally Enclosed Fan Cooled)?
Having the Mobility Kit gives you the option of easily moving it out from between things to use it, back to between things when not in use. Mine's next to the pocket door separating the two halves of the shop. For LONG rip cuts I've got 16' of room on the infeed side and 18' on the outfeed side. In its normal use position I've got 5' behind the blade before I run into a drill press cabinet and drill press.
The foot brake is handy to have. A 16" cast iron wheel can spin for a LONG time without it.
What blade guides came with it. Think about getting the Laguna Tools Ceramic Guides. Two points of support on either side of the blade, they can be set right against the blade and they wear VERY slowly.
Unless you have a very powerful dust collector, the dust ports (on at the bottom left of the lower cabinet, and one in front below the table) and pretty useless with so much open area under the table - but better than nothing I guess.
Enjoy the new toy. You don't realize that you NEED a good bandsaw - ' til you get one.
Don't let the neighbors know you have it or they'll be bring over all kinds of stuff they want cut in very unusual ways, I've done a dozen or two large ply flowers, fish, ducks, birds, ... and with a metal blade, a firewall out of sheet steel, tubing for jeep bumpers, . . .
The foot pedal does 2 things, one is it stops the motor with a switch BUT it also stops the blade when press hard enough. This is what the maker says to do as it is a safety factor.
The RED button is one of those that stops the motor but the wheels in this thing are so heavy and well balance that the blade will keep moving for about 5 minutes. The RED button is for emergency stopping only I guess when you need to hit it and get the heck away from the machine.
As far as letting the pressure off the blade that isn't really necessary either but it really doesn't hurt anything to do it. I never do. The Taiwan saws all have a spring assemble that is made of cast metal and letting the pressure off does help them last longer, I had one that the screw that tightens it came right through the bottom. But this machine is built like a tank. The tension assembly in it is steel and I don't see any chance of constant pressure bothering it. Also, this machine has flat rubber (NOT crowned) and I like that feature a lot also. It's also harder that the Asian imports that are crowned.
JOHN: forgot to mention that you are suppose to adjust the top wheel tilt so the teeth of the blade runs overhanging off the front of the wheel, the teeth should NOT run on the rubber part or the metal part. just adj till then hang off. I'm telling you all this because you indicated you picked it up used and I don't know if you have a book with it. Think you can download it from web site also. What I just said applys to all blades except 1/4" and smaller, bigger dial in over hang.
Charlie the HP on the MM16 like John now has and mine is 4.8 HP TEFC.
I don't know why you recommend changing the guides as the one's on it are great. They are all bearings that turn, no rubbing friction to cause heating.
The surface of the bearings that touch the blade are about 1.5 inches in diameter.
These folks also make another 16" saw that is called an E16. It is a lighter built machine and shouldn't be compared to the MM16.
Charlie, dust collection on this machine is done with a box enclosure just below the table, you are not dealing with the whole bottom area. The box is about 8" x 8" close but not exact numbers. There is a slot that you put a plywood block where the blade exits this boxed area to help seal it. The top of the box is opened more or closed off as desired with a panel which you can see in the pic John posted. If not familiar with the saw it may be hard to see it, it it is controlled by the black knob on the front of the bottom door upper right side, loosen it and the panel slides up or down for more air intake just below the table.
Thanks Don. I got the manual with it. The saw is virtually new. I haven't had time to read the manual and really probably won't get the machine installed where I can use it for another week or more. Got too much to do. Santa's "Elves" have to keep busy this time of year if you know what i mean.
I checked out the dust collection area this morning. With just a little modification I think I can really seal off the area. Since the dust collecting shroud is metal and covers a pretty large area under the table (and as Don said is adjustable in height) I think I can add some small pieces of plywood held on with rare earth magnets to really close the port off.
John, you will love this machine! I've had one since they added the 4.8 hp(?) seven or eight years ago. I bought the machine from Sam Blasko when MM had their office in Austin.
Thanks for the magnet idea to fasten the dust collector box in place, I tried several ideas to close off that area and haven't been satisfied to this point. You will get dust in the bottom box not matter what you do. I've been told that if you will cut a 4 inch diameter hole at the bottom left of the door and connect your dust collector duct it greatly improves the dust collection.
John, Great score & price too. I got this same saw. I've had it for a couple of years & love it. I love the fact you can actually stand a log about 16" long on end and have the resaw hieght & power to cut it in half.
I struggled with a 14" Delta with a riser block & 1 1/2 hp motor cutting a 10" long log on end in half.
I really fail to see why you would want to seal off the box anymore than it is? Dust collection needs air to work correctly. The more you seal it off the less air it can get and that will hender it working properly.
As far as the lower area goes (where the bottom wheel is) you do have a block of wood in the bottom of the box where the blade exits it don't you? You cut a block so it will slide into that area and you do it as the blade cuts a slot in the block, you can do it with the saw off and turning wheel by hand.
I used plywood for mine and cut the back end of it so it was thin enough to slide under the back and catch on the metal in the back. I did put weather stripping on the edge of the boxes metal where the door will close against it.
I do have an Oneida cyclone doing the sucking with 5" hose converting to 4" right at the box. I did tell Blasko that he should inform the Italians to increase the size of the port to 6".
John- You are going to love this saw. I've had the MM16 for several years and wouldn't trade it for anything. I made two slight modifications. The table was a little low for me so I built a platform for the footprint to sit on and raised the saw about 4" or so....much more comfortable. I also pulled out the plastic insert in the table that surrounds the blade and made a solid one with a saw kerf in it. I like it much better when sawing small pieces. The dust collection is not real good.....but is there any bandsaw with good dust collection? And MiniMax is one of the best companies I have ever dealt with. Their service people are so helpful. Congrats.....you just upgraded by leaps and bounds!
