OT - Recommendations for an Oscillating Multi-Tool
Rob Wallace
Rob Wallace
I have already dropped the hint that for my gift this year from the family, I would like a corded oscillating multi-tool for both home improvement projects, and to have another tool for helping carve my bowls and vessels, and other wood sculptures I am working on.
I'd be interested in recommendations from others owning one of these tools (which recently have really come down in price) on which of these tool brands and models perform well, allow quick tool changes, have inter-brand compatible accessories, and in general is a "quality" tool. My "gifters" have asked which brand and model I would like, and I don't have any kind of a fact-based answer for them. I do know that I don't necessarily want a 'high-end' tool like a Fein with the associated high cost of proprietary-only cutters, etc., but would like something at or near 'contractor grade' so the tool performs well and lasts.
Does anyone have one of these oscillating multi-tools that they really like?
Thanks for whatever advice you might have!
Rob
Re: OT - Recommendations for an Oscillating Multi-Tool
I had a MX30......Model Bosch Multi-X and liked it a lot. Also had a similar battery powered version and like that a lot until I got the corded one. The power increase is amazing. Still like the battery tool, but the difference is night and day. I highly recommend the 3 Amp corded version with the Quick Change tool release lever. The Battery tool required you to use a Allen Wrench to change the blade. Again, not bad until you use the other version. I just looked at them on Amazon and they ranged from $169 up. A second version was a hundred buck more and appeared to have some extra accessories.
I highly recommend the tool in general. We keep finding new uses for it. The saw blades are obviously useful, but so are the scrapers, grout blades, and the sander pad. Its one of those tools that once you get one you find it hard to believe you waited so long. (Mine was stolen and I will be replacing it soon.) I still have the battery version. Unfortunately, the accessories are too expensive.
PS, the Bosch tool will accept most types and brands of blades. Double check this, make sure yours will accept multiple types and brands.
Dick Coers
For what little I use one around the house, the Harbor Freight version has worked well for me. It's loud, and vibrates pretty badly, but cuts well. The Fein I use at work is really nice, but precision is not what I am after with this tool. I've not sanded with the cheap one, but don't like sanding with these anyway. I just use it for cutting. On sale for $15 right now.
Harry Robinette
Harry Robinette
If you think your going to need an oscillating saw then buy a Fein. Yes I know they are expensive but if you think your going to use a osc saw buy the one that's going to stay around use after use.Oh ya I can use the cheaper blades on my Fein.
PSS on the Bosch tool, get the 3.0 amp version as it has the blade release Handle. It works well and is MUCH more convenient than the Allen wrench method.
Rob Wallace
Rob Wallace
Thanks Harry -
I am concerned with the brands that require proprietary mounts for the blades and accessories.... ...will go with a 3 amp version whatever they get me....
Doing some price, brand, and model research to see what's on sale and whether and how any of the other brands stack-up to the Fein versions of this multi-tool.
Decisions....Decisions....
Rob
Rob Wallace
THANK-YOU for your comments!!
Rob Wallace
After more web and catalog searching, and the comments here, I am now considering the Fein, Bosch, Porter Cable, and DeWalt (corded) versions [3.0 amp] of their oscillating multi-tools. I took-out the Rockwell and several of the more 'handyman' grade tools from the list....
Many comparisons still to do, but an informed decision is necessary for both peace of mind and anticipated longevity of living with the results of the decision being made!
Thanks again for your input!
Rob
Re: THANK-YOU for your comments!!
Rob I'll be interested to hear what you can do with that saw that you can't do with other tools, at least as far as carving goes. I don't have one yet and have managed to carve what ever I want but I'm always looking for a better way.
Steve Kniffen
Rob,
If you're going to use it a lot, definitely go with the Fein or PC. If you don't expect to use it a lot, go with the Harbor Freight one. Lowes sells an adapter that makes different tools fit different machines. It even includes the HF brand.
Steve
Rob, whatever you choose,
Keith Newton
Go ahead and get a 6" slim tapper file, and a magnifying visor to sharpen the blades with. I can file one about as fast as changing the blade, and I'm sure you have noticed that they make their money on the blades.
They may come alternate ground, but I just file them all straight across, and they cut fine.
When it comes to using them. I rock them back and fourth, trying to give the dust a way out. If you try to use the whole blade, just straight in, that generates a lot of heat, which is not good for the blade.
I wasn't sure I needed one, so bought the HF just to see, and found it to be surprisingly good, and use it for a lot more than I expected.
Randy Gleckler
In case your still deciding and would like some more input.
I have 2 a Porter Cable and a Harbor Freight. Both are corded and I really like both of them. The Harbor Freight I use to cut the little nub off the bottom of my bowls. Works really well for me. The Porter Cable I use for everything else and I reach for it on about 9 out of 10 projects. The ONLY thing I would complain about is that the blades for it are not as available locally. There are some that say they will work, but I don't find they fit as well as the OEM ones. Other than that, I love the thing. I'd probably recommend the Bosch since it appears to available around.
Rob Wallace
Thanks Keith!
Rob Wallace
Given that I re-sharpen my 105" 3 tpi band-saw blades at least twice before retiring them, knocking off the sharpening of one of the oscillating blades should seem like nothing! Great idea! I already have the small files needed to do this,
I'll be having a look at several of the 3 HP models over this weekend, and trying to get my hands on actual tools to get a feel for how they might work for me....tool shopping is one of the ONLY kinds of shopping I enjoy. With everything else, it's in-and-out of the store as quickly as possible.... clothes, shoes, food, etc....it doesn't matter. Most observers say it's a guy thing.....
.....well, back to that stack of term papers with my name on them to grade....54 down, about 52 to go.....
Rob
PS - Now 'tis the only season we use the word 'tis.....
Rob Wallace
Rob Wallace
Still deciding! Thanks Randy!!
Doing more "research" this coming weekend!
Rob
Re: Thanks Keith!
Keith Newton
"I'll be having a look at several of the 3 HP models" heck, if you are going that far, you might as well go on and get a 5 HP one. Ha,
Last night I was using mine to square the corners of some 1"x 4"x 2.5" deep mortises, that I had routed with a Tage Fried jig. Sometimes it is a pleasant surprise how I find new ways to use it that makes something easier.
