Re: Lathe Selection
Greg Haugen
Ken, here's an important question. Do you have service centers nearby for any of the lathes? The best lathes out there can have issues and if you don't have service.....well you know. Locally, for me, the dealer is a service center for all 3 brands. Delta's lathe is a decent lathe, there has been some issues with the newer ones (Delta has changed hands a couple of times in recent years) and some places have stopped carrying the brand altogether. General is another decent brand. I've had General lathes in past. They've been good machines. The new Jet is an incredibly machine. The casting is heavy duty, the speed control on the VS model is excellent, it has a locking spindle (not just a spring loaded lock), and even though the stand isn't as inexpensive as other stands for midi lathe, it's the heavier duty than any other that I've seen. There are components, the upper and lower components, are cast iron not just bolted and welded steel. I rarely change belt positions on it since it has a nice range in all three positions but when I do, the mechanics of it are simple, fast, and easy. To say the lathe is quiet is an understatement too. I really like my Jet.
Between the three lathes, Delta makes me nervous with the customer service issues (even if you found one of the older-2 years or more-lathes you'd still have to deal with the current customer service). General is a decent company, nothing bad can be said about them. I do believe there's a warehouse in the USA now so getting components and parts isn't an issue like before with going over the border and shipping. The Jet lathe is rock solid, a nice machine, and Jet is readily available from a lot of places. It is probably the most expensive of the three though but it's a nice machine.
Where are you located? Are you able to try them out at someone's shop?
But as I said, before you make a decision check on service options for all of the brands.
