Something I have never seen *LINK*
Bowl Machining
Bowl Machining
Re: Something I have never seen
Mike Stafford
Well, that sorta takes the fun out of it.
Gotta love that scraper he is using in lieu of sanding, huh?
I can't believe it ran as true as it did with the pressure those 3 jaws pit on the tenon. Must be some pretty big dents in the tenon.
A monsterous old metal lathe, and I ...
JamieDonaldson
.......wonder if the cutter was just a big scraper bit?
Greg Haugen
That chuck is the epitome of a "knuckle buster".
A handheld cabinet scraper on the interior......that takes skill, and guts for even trying it. Imagine a catch and having that scraper pulled from his hands.....there would be digits missing. There's a tutorial by Dale Larson on his techniques for turning bowls and he mentions that he removes the tool rest and then uses a cabinet scraper on the outside of the bowl but mentions, in capital letters, to never try it on the interior due to the risk.
If I use a cabinet scraper on the inside its with the lathe off. Never on. If you use it on the outside turn the speed way down. That thing will really hear up a d burn your hands
Emmett Manley, Lakeland, TN
No face shield or even safety glasses yet look at all the impact dents on the adjacent wall.
John Lawson
I was rather impressed that he got the inside curve he intended spinning the long-feed and cross-feed cranks by hand. You can't do that your first day on the job...
That was the thing I was pointing out ;-)
Well it helps that he had a scraper with
what looks like a 2 1/2" radius. Still good hand and eye coordination. I'll bet he can chew gum and pat his tummy at the same time.
Re: Etch-a-Sketch expert, I bet.
