REAL MILK PAINT
Saving and storing wood
Ill be doing a demo on harvesting and saving wood for the Chattanooga club. I've been sort of putting it together for a while but could use some more photos a d suggestions of how you store a d save your wood. Do you label the species. Do you weight them and if so how do keep track. Have you used a moisture meter and what are its draw backs.
If you have any good photos send the larger files to johnclucas@charter.net. Ill try to put an article together to post on wood central so it can be shared with all
Re: Saving and storing wood
Bill Turpin in WNC mountains
The wife and I turn mostly small, kiln-dried stuff. Her theory is: when you find good, solid stuff and the price is right (~$0.50 for an ornament sized blank) buy it whether you need it or not. You'll never see it that cheap again! She has two shelf units filled with plastic, numbered bins. She has a spreadsheet with size, species, and price listed. Example: at a symposium in north GA about five years. Clarinet bell blanks of solid Afr. blackwood for $4. (3.5" x 3.5" x 4" no sapwood or cracks) I think we ended up with fourteen. I laugh every time I see it at $120/bd foot.
Bill I bought 2 of the clarinet bell rejects from Big Monk lumber. My son played clarinet so I am going to make him a box. Now that I've taken up metal spinning I have the skills to do what I had in my mind for that box. Still need to do some searching at flea markets to find some things but I should be able to build it before too long
Darryl Schilling
I have a clipboard with a list (1-100). Different woods assigned to a number. As a new wood is obtained, goes on list as the next number. Number is written on wood with Sharpie, then wood stored.
Then, I sort by alphabet (and print) then by number (then print). If I want a specific wood, I go to the alphabet one. If I pick up a piece of wood with a number on it, I go the the numerical list.
It works for me.
Bill Howatt
When I get a batch of free wood I rough turn it as soon as possible. I don't get so much that I have to try to remember where I got what if I have to let it sit for a while.
I have a log book in the shop. When I rough turn a piece I write in the book:
GT Date -1 Description (GT==Green Turned)
The description will typically be similar to: Cherry from Fred Blogg's tree in Kukamunga. If appropriate: End-grain sealed on outside. CA glue put on knot. or anything unusual.
The next entry if for a piece from the same tree would just be:
-2 Same as -1.
I write the "matching GT number" on the bowl before storing it. Usually in a paper garden waste bag until mostly dry and then it is transferred to a shelf in my basement.
I leave a few lines between the entry for each piece. When I finish turn the piece I enter in the blank lines: the date with a description of anything unusual such as filling with coffee grounds, type of finish, and if I know, what happened to it such as given to Mary Smith for her birthday.
If I buy dry blanks, typically exotics, I just write on them the species and maybe where I bought it. I enter the data on finishing and its disposition in my log book when completed.
Bill
Wow you guys are much more organized than me. Thanks for posting
Dale Bonertz
I also mark my blanks/blocks/etc. but I keep it simple for me. MAP is maple, E is elm, HB is hack berry and etc. I enter these codes into my computer and print them to hang in my shop so I and others know what they are. When I dry something for myself I also add a date to the piece of wood. I can't use what I have dry fast enough so there is always something six months old or older to finish turn and I know it is dry. Not saying you can't find something not marked in my shop but it would be hard since I make this a habit when it comes in.
dougturner
John, I rough out bowl blanks with a McNaughton corer, paint with wax emulsion and write the name and date on the back of the bowl with a sharpie pen. I turn to final dimension 6 months or later. For spindle stock I rip the stock on a band saw staying at least an inch from the pith, wax the ends, label and date. Platter blanks are cut about 1" from the pith about 2" thick , rounded, waxed dated and labeled. Pen blanks are cut slightly oversized and if the type of wood tends to crack I sometimes freeze for 48 hours and the dry in the refrigerator for 2 weeks (my wife hates this, but loves the pens). Ornament birdhouse roofs from limb sections 3" or less in diameter are final turned directly from green wood and left to dry untreated.
Doug
Brad Vietje
Brad Vietje
Lots of good ideas from those with much better organization than me -- very much appreciated. I hope to establish a new shop soon, and really should get more organized. For now, I rough turn, date and store, and that's about it. No log book, no real records at all. I like green turning a LOT more than finish turning and sanding, so I get a mess of air-dried pieces, and there's always something dry enough to turn if I need something quickly.
If I start doing more turning for sale or production turning, these record keeping ideas should help a lot.
Safe spinning,
Brad Vietje
Newbury, VT
Jesper, Denmark
Re: Wood hoarding opportunities come in spurts...
Jesper, Denmark
Like when someone finds a good log for sale at firewood price. Usually, the "community" gets a few guys together to saw and divide, and all of a subben, there is 1000 lbs of sycamore or whatever in your drive.
I cut it lengthwise to remove the pith and seal the ends. Resistant species like Black Locust stays outside under the boat. less resistant species get into the garage and gets turned rough as soon as possible. Pieces not so prone to checking go in the attic together with the roughed out bowls in the fall. If they survive the next summer, then they will last forever.
Roughed out bowls get put in brown paper bags for around three months, then taken out.
I write the date, the weight and the species on the bowls and just the date and species on uncut pieces. Better than 75% of the uncut pieces survive to be usable.
that's why I started this research
I get wood in spells and it always comes at the worst times so it sits in the driveway and goes bad. I started working on ways to prolong it's salvageable life. I have some ways that work for me in my particular environment and wanted to see what other do.
I'm also as bad or worse than you at labeling and organizing my wood so it was good to hear how other do this.
