Second turning on a deep natural edge bowl
George Balock
George Balock
Hi, I haven't posted here in a while. Too busy. I have a deep (9") and large (18+") diameter natural edge bowl that I am getting ready to turn for the second time. I usually just catch it between the tail stock and my chuck, but on this one, the bowl won't clear the headstock. I tried using block of scrap in the chuck as a spacer, but there wasn't enough friction to drive the bowl. Any suggestions on how I might get this back on the lathe?
Re: Second turning on a deep natural edge bowl
Don Orr
Add some kind of high friction material between the scrap block and the bowl?
I use the rubber jar lid openers
Bill Howatt
That should do it but if it doesn't and it is small, consider making the scrap block fairly large in diameter and shaped similar to the bowl bottom.
I often use my homemade vacuum drum chucks for this purpose if they are already on the lathe. They are black ABS pipe couplers about 5-6" dia with a thin layer of closed-cell foam on the rim.
Bill
There are many materials that will .......
JamieDonaldson
...enhance the friction grip for a jam chuck to wood mount. I found tough rubber pads at cooking supply stores for removing stuck lids from jars, squares of rubber router pads, old computer mouse pads, rubber shelf liners as used in kitchen cabinets, chunks of my old scuba wet suit, section of old rubber tire tube, etc.
Brad Vietje
Brad Vietje
Hey George,
I've seen lots of people re-mount a bowl on a long "stub" used as a friction chuck, but I never do that unless I have to. That supports base, for turning away a foot or chuck marks, but really doesn't do a thing to support the sides of the bowl.
I have a series of turned disks of wood with a small hole to match my "woodworm screw" -- usually from Pine boards, or made from Fir or Spruce 2 x 8, 2 x 10, or 2 x 12. I can shape the outside of these as needed, and cushion the contact area with foam, a piece of terry cloth or whatever comes to mind, and I get much better support of the entire bowl as I re-cut the tenon and re-shape the entire outside profile, if that's what's needed. I would much rather do this between centers than after re-mounting on a chuck or faceplate, especially if the object has warped out of round, or if the walls are slightly thin.
Even if I've re-shaped and re-sized these disks, and they get smaller and smaller, they are still useful for the next size down; every now and again, I simply find a scrap of 2 x 10 or 2 x 12 and make another large size to replace the old ones that are getting smaller.
May not meet your needs, but sure has come in handy for me.
Safe spinning,
Brad Vietje
Newbury, VT
