Veritas - Innovation in Tools
Looking for a solution
Alan Sweet
Alan Sweet
I want to turn pieces 1 1/2 long and 1/2 wide. They will have an 1/8-9/64 hole drilled up the center.
I've tried to make a couple mandrels but have not been successful. I've tried TBC but not enough tension to keep the small pieces from stopping when I am applying gouge or cutter.
I must be missing something simple. Any ideas?
Re: Looking for a solution
I assume you're talking inches......
JamieDonaldson
...rather than feet here? And what material, number and spec variations are required?
John Lawson
John Lawson
Assuming inches, you could drill the blank, then use a light pull drive on the headstock end and a live cone center in the tailstock. You could gin up something like a light pull drive out of parts on hand.
Alan Sweet
Re: I assume you're talking inches......
Alan Sweet
You are correct, inches. Various woods. I'll be making about 3 dozen maybe a few more. They will be used for pulls for lights and fans in two relative houses.
I may make a few of them acrylic. I've been able to make a few by experimenting with making mandrels out of 3" nails. I tried using 1/8" rod and 1/8" 6-32 threaded rod. The results were less than desirable. After awhile of being turned the piece starts slipping. I tried running the pieces over my router table first to decrease the starting diameter, but it doesn't work the well. Especially with the small size.
I was hoping to use my scarps cutoffs. But I may have to turn them with longer pieces and part off the pulls. That allows me to chuck much larger pieces and turn off the pulls. That maybe my last option.
Alan Sweet
Alan Sweet
Ok. I'm all ears . What do I need to make a light puul drive?
Use a spot of double-sticky tape ...
Doc Green
Alan, my suggestion is to go back to your mandrel and use a small spot of double-sided tape between the blank and the bearing surface of the mandrel at the headstock end. Either carpet tape or woodturners tape will work.
The mandrel needs to be nothing more than a piece of wood held by a chuck or faceplate with a short section (1/2") of a nail or rod installed at the center.
Drill the blank, apply the spot of tape, slip it over the mandrel (nail), apply pressure with a cone center at the tailstock ... and away you go.
I've used this technique many times to make wooden hose barbs for vacuum systems. The barbs are 1/2" at the largest diameter and 1.5" long overall.
Mike Stafford
Mike Stafford
Another option would be to turn the pull as if it were a finial. Start with a slightly larger blank, longer and larger so that it can be held in your chuck jaws. Drill the hole to the depth needed and start turning your desired shape. I am assuming that your difficulty is arising because you are having trouble holding the relatively small blanks. By turning the piece as it is held in the chuck you should be able to shape it as desired and then part it off with just one end to touch up.
Alternatively Craft Supplies sells a light pull mandrel. See below.
Steve Kniffen
Alan,
One solution may be a Beading Mandrel sold by PSI ( http://www.pennstateind.com/store/PKMBEAD.html ). It's a 1/8" threaded rod, but has spacers that can be used like bushings to hold the blank more securely and has end pieces that fit in a drill chuck or mandrel saver just like you'd use for a pen.
Steve
Mike took the word out of my mouth
Alan, please correct your e-mail address
You're using a bogus address AND you've requested notifications when people respond to your posts, so every time our system responds to you, the notice gets bounced back to me.
I appreciate your attention to this. Go to Set Preferences and enter a valid address. You'll need to correct it in your profile, too. Or, if you don't want to receive the automated notices, please uncheck the "e-mail me when someone posts a reply" box at the bottom of your next post. That will reset your cookie and it will remember that you don't want the notices.
Thanks.
A couple of thoughts.
Do you have a four jaw chuck? You can take the jaws off and use the slides to hold small pieces. that way you only need about a half inch or less in the chuck and the chuck face is fairly smooth and not much of a finger biter. If the slides project beyond the chuck body you can run a piece of tape around them or you can get a piece of and inner tube to cover them.
Another idea is to use a sander to grind a cone on the end of the blank that is roughly a No. 2 Morse taper or whatever matches the shaft of your lathe. Then drive the blank directly into the shaft. the taper only has to be about a half inch long. I turn icicles like this all the time. Done at least fifty. You could probably whittle the end if you don't have a suitable sander. You can bring the tail stock up to press it into the shaft while you hog the wood away and back it off while you clean up the end. If the hole goes through lengthwise you could put a chuck in the tail stock and drill it on the lathe. Then part them off. Drilling them on the lathe would work if you use the chuck body as above. Working with just the shaft of the lathe is very comfortable because there is no chuck in the way.
Keith Tompkins
Keith Tompkins
MIke, I think you nailed it.....hold the piece in a chuck, turn multiples from a long piece of stock. The hole drilled in the piece could be used to bring up the tailstock if necessary. Some people advise against turning spindles held in a chuck, but I personally use that method all the time.
Rex Stallion
Faced with a similar problem, I had a spare drive center turned down to 3/8 for turning some
very small spindles. the drive has an adjustable center point that is 1/8 thick. hope this helps, Scott.
Alan Sweet
Re: Alan, please correct your e-mail address
Alan Sweet
My email address is alanfsweet@hotmail.com. I looked at my profile and it appears to say that my email is alanfsweet@hotmail.com Under the assumption that there might have been some hidden character or blanks I did not recognize I tried to input a new email of alanfsweet@hotmail.com
I got the following error...
If there is something else I should do, I don't know what it is
Alan Sweet
Alan Sweet
I was wondering. That is a hotmail address. I am NOT set up for outlook emails. I know there is problems trying to send to hotmail from outlook and vice versa. Is that a possibility?
Brad Vietje
TBC ?
Brad Vietje
Alan, I think I'd turn a mandrel out of some hard wood like Hard Maple, Hophornbeam, Osage Orange, etc... with a small flat toward the headstock end, where you would place 2-sided tape, and use the tailstock to push the blank up against this for extra "grip-tion" (or "stick-tion", in this case). This is essentially what Mike and John are saying, but instead of buying a mandrel, I think you could just make your own.
Safe spinning,
Brad Vietje
Newbury, VT
Hotmail is the culprit
Apparently, a range of IP addresses at my host has managed to get on Hotmail's block list because of some kind of spam infraction by one of the servers at their facility. The matter is currently being addressed by the two parties and should be straightened out within the next 24 hours.
I appreciate your responses, which led me to dig deeper into the reason for the bounced messages.
In the meantime, I have unchecked the "notify me" boxes in all your posts in this thread. You could help by replying to this post and unchecking the box at the bottom of the form, in order to add that preference to your cookie.
Sorry for the inconvenience. There was more to this than I originally thought.
Alan Sweet
Re: Hotmail is the culprit
Turning Between Centers ?
