Glue block process
Lyle Jamieson
There has been many good suggestions that work and many reports of failures. There are a lot of ways to hold wood on the lathe but I use glue blocks and faceplates and never use chucks. The reason I use CA glue, thick CA glue, is for strength and speed. The sheer strength of a properly executed glue block is enormous. I believe Betty is correct that this process is safer then a chuck. Yet it is brittle so it transfers the power without vibration. Hot melt glue will work for relatively small turnings but will result in vibration limitations with larger work of when you might want to pour the coal to it and turn faster. The other glues have a longer waiting period. I have used this process for decades and never have failures, even with very large, natural edge bowls with voids. http://youtu.be/y8b35iq4LTA http://youtu.be/rbZXEBIHVOU
