Ginkgo Nocturne
Ginkgo Nocturne
Ginkgo Nocturne
Bill Clark
I’ve been playing with several new forms lately that stay within the oriental theme I like to work with. One of my favorite ceramic oriental vessels is the classic ginger jar. I’ve turned several small prototypes but found I was still searching for the most eye appealing form. I tried yet another variation which resulted in this piece. As soon as I rough turned it, I knew I was on to what I was looking for. I completed the outside adding a groove close to the base to separate the textured field that was to be added above the base. The vessel was then hollowed to ¼” walls. The lid was a bit complicated because it was small. It had to be sturdy around the rim yet 1/16” thick for the pierced center.
Following the turning I branded the two different sized ginkgo leaves in a random pattern on the outside. The leaf veins were burned individually. The entire field was then textured, except for the leaves and area below the groove at the base.
The entire vessel and lid were then airbrushed with a light TransTint dye to add the warm golden brown color to the base, leaves, lid and oriental themed handle. I then painted the field around the leaves with black gesso. The black ring around the lid and handle mount was also painted black. The entire piece was then sprayed with a matte finish to ensure a uniform low gloss reflectivity. This also seals and protects the dye and gesso finish.
The piece is 6” tall including the lid and 5 ½” in diameter. It, along with 2 others, are currently on display in del Mano Galleries online “Turned Wood – Small Treasures” Exhibit.
All comments and critiques are welcome.
Re: Ginkgo Nocturne
Stunning - Ginkgo Nocturne
Henry W
"As soon as I rough turned it, I knew I was on to what I was looking for..."
Agree with your eye then - that is stunning! Beautifully done.
Henry
Re: Ginkgo Nocturne
Re: Ginkgo Nocturne
Bill Hayes
Very nicely done. Did you make your own leaf brand? If so How?
Re: Ginkgo Nocturne
Beautiful Bill!
Jennifer Indy.USA
This is a lovely piece Bill. Looks meticulously crafted with attention paid to every last detail.
Bravo!
Jen
Re: Ginkgo Nocturne
Re: Ginkgo Nocturne
Bill Clark
Bill, I use 20 gauge nichrome wire. I carefully bend it into the shape I want. This takes a lot of practice. I usually loose 1 or 2 before I get the shape I want. These larger brands require a high output controller. I used to use a "Burnmaster" but found for my larger brands I still needed more wattage. I'm now using a self built "Graeme Priddle Wood Vaporizer". You can do a web search and find the directions to build one from a NAPA manual battery charger. Due to the heat I'm now making my own pens to hold the nichrome tips.
Re: Ginkgo Nocturne
I'm just amazed at the uniformity of.......
JamieDonaldson
...that gesso finish, without any brush marks or lumps! ;)
Re: Ginkgo Nocturne
Oh, my!
GaryG in MD
That was my immediate reaction.
Stunning piece! ...GG
Re: Ginkgo Nocturne
Bill Blasic
Re: Ginkgo Nocturne
Bill Blasic
Bill,
A superb piece!
Bill
Re: Ginkgo Nocturne
Re: Ginkgo Nocturne
matt overton
Superb execution! I love it.
Re: Ginkgo Nocturne
Spectacular!
Re: Ginkgo Nocturne
Re: Ginkgo Nocturne
Randy Gleckler
That is a fantastic piece, I really like it.
Re: Ginkgo Nocturne
Re: I'm just amazed at the uniformity of.......
Bill Clark
Jamie, I've been using Black Gesso for years. Andi Wolfe gave me a tip to thin it a bit with water. It flows out much better and the lumps and brush marks flatten as it dries.
Re: Ginkgo Nocturne
Re: Ginkgo Nocturne
Bill Clark
Thanks all for the encouraging comments.
Re: Ginkgo Nocturne
Leo Cuellar
Wonderful!
Leo Cuellar
Simply gorgeous, Bill. Your work is always a delight to behold.
Re: Ginkgo Nocturne
Nice, Bill! *LINK*
Where did the piercing pattern come from?
Awesome work, as usual. Thanks for posting!
Turning and Burning Contest
Re: Ginkgo Nocturne
Re: Nice, Bill!
Bill Clark
Thanks Ellis. I started piercing a couple of years ago. I like the added feature to my work but it is very tedious and requires a lot of breaks. My shop time is limited so I only do a few pieces a year. Hope to see everyone at the next AAW symposium.
