Walnut knitting bowl
Trying to get ready for Christmas and have a long list. This is the first.
Re: Walnut knitting bowl
terry gearhart
Nice knitting bowl John, my aunt has a
yarn shop.......called the Yarn Basket.......
Hmmmmmm.............I wonder........
would you mind sharing the size
Thanks for showing
Jeff Rich
Yep, had a request for a yarn bowl and I had to look it up!
Nice work !
It's about 8" wide 6" deep. I don't know what is correct. I made it about the size of my mothers basket
Don Orr
Really like the yarn slot.
Randy Gleckler
I saw this last night at our meeting and its a Great looking bowl. Never caught up with you to tell you and to say Hi. So Hi and.... this is a great bowl John, really like it.
Leo Cuellar
Very nice work, John.
Alan Sweet
John, a couple of questions.
1) How thin are the sides?
2) Is this finished?
3) How did you cut the side? The open part where the yarn comes out. I was thinking that you may have drilled a number of small holes or a fine tooth saw or.. Then just sanded?
I am going to give this a try.
Alan It's a little thinner than I wanted. It had a bad spot in the side and when I finally cut it away it was about 3/8" thick. That's probably not bad but I had intended to leave it a little thicker.
I cut the slot with a coping saw. It was a hassle because my blade had too course a teeth. Get a blade that has 3 or 4 teeth engaged at any time in the thickness of the bowl and you shouldn't have any problems.
I fine tuned the cut and shape with a dremel and several bits. I sanded the slot with sandpaper either wrapped around a dowel or glued to a stick.
I finished this with about 3 or 4 coats of Minwax wipe on Poly and then buffed it with the Beal buffing system.
Thanks, John.
Splendid......
Jesper, Denmark
I have a bowl with a crack in it, where your idea of the knitting bowl just may be the saving grace.
I presume the idea may be plagiarized?
Re: Splendid......
John Veerkamp
The idea has been around for a long time. Pottery ones were the first I saw. I've been making them for some time. Some Knitters like them with just a hole in the side. Others like this type with the slot. The ares where John has the hearts is where the yarn catches to keep it inside the vessel. I often make a lid to fit. It can help keep the yarn clean and keeps playful cats out of the knitting. They make great gifts to crafters and sell well in those types of shows.
