CA glue brands
CA glue brands
CA glue brands
Don Evans
I recently picked up some CA glue that was branded Titebond. I've never used it before and am pleasantly surprise at how well the bottle works. They have a much better cap design than any of the others and I've not had one single stopped up spout with them.
Amazing!
I always wipe the nozzle immediately to remove any glue at the hole with any brand also squeeze and rapidly release to suck glue out of nozzle back into the bottle then wipe but with other brands it will still clog.
Do same with the Titebond and it doesn't. One difference is they put a little pin in the cap that goes back into the hole, simple but if you do the clean up it is effective.
No affiliation but then should send me a free bottle, huh?
Don
Re: CA glue brands
Lyle Jamieson
Re: CA glue brands
Lyle Jamieson
I leave the top off. Been doing that for 20 years now. Never any clogged tips. Just store separated from the accelerator.
Re: CA glue brands
Re: CA glue brands
Wally Dickerman
I agree...When I open a CA bottle I toss the cap. Putting the cap on just holds glue up in the spout.
If I do get a clogged spout I remove it and put it in a glass jar. Over a period of time I'll have a few in the jar. I pour in some acetone. I end up with clean spouts and some hardened glue in the bottom of the jar.
Re: CA glue brands
Re: CA glue brands
Tried leaving the cap off. Didn't seem to help with the brand that I use. I do find there is a difference in the characteristics of different brands. Some are more brittle to impact, and some don't clog the tips as bad. Wish I could remember all the brands I 've used to discuss them but alas I'm too old. Lets just say that all brands of CA are not equal.
Re: CA glue brands
Re: CA glue brands
Don Evans
John after a little though based on what you said, I don't think all the bottles are made of the same material composition. The Titebond for instance seems to be much stiffer (or perhaps thicker) material that others I've tried. It also feels different.
That may also be a factor in your comment about some stop up more than others.
I also don't use any CA for building anything. Only use it for temporary things. Like pasting letters printed on paper to attach them to bone or mother of pearl to cut them out for inlaying.
Don
