SketchUp's Free - working on flattening the learni
charlie belden
Peter (and anyone else into or getting into MultiAxis Turning (MAT))
The 3D modeling software, SketchUp, is free and available for Windows, Mac OSX and Linux.
Like any tool that's made as a Solution Looking For Problems To Solve (an old HP ad campaign for their programmable pocket "caculators"), it has a lot of Whistles & Bellls and you'd have to climb a very steep learning curve to be able to use them all - for everything. Like eating a pie, if you try and eat it ALL, it's upsetting. But - IF - you start with a small piece of the pie - it's satisfyng. And you can always go back for Seconds if you're still hungry.
For turners - of ROUND - creating a profile and then "turning" that profile into a Virtual 3D object is pretty easy. There are plenty of YouTube videos on how to do that and in half an hour you could learn to do that - create profile - "turn" it. And once you've got a virtual 3D model of the idea, you can copy it and tweek it - "stretch it" - just vertically, just horizontally or any combination you want.
Once you can create a profile and "turn" it, you can create a profile for each axis you want to turn on, "turn" each one into a 3D model and start overlapping them - which is what you do when working in MAT (Multi Axis Turning) - and SEE the "outcome" from any vantage point you choose.
Here is an example of how to use SketchUp for creating Virtual Prototypes.
1. For this example I'm going with a "bead" profile for each axis
2. Offset one of the bead profiles a half bead diameter up or down
3. Take HALF of each profile and offset the axis that it will be turned on. You'll see why in the next step
4. Overlap the two profiles so that the "common volume" includes HALF of your two bead profiles
5. Copying each of the profiles from Step 3, "turn" each one to create Virtual 3D models of the turned form.
6. Copy the "overlapped" 2D version from Step 5 and move the centerlines of your 3D models so that its axis lines up with its 2D axis
7. "Intersect" the two 3D overlapped models to get the their "common volumes" - which will be the "outcome" that would be turned on the two axes.
If the two axes parallel each other the "outcome" shown in 7a will be the result.
If you slant the axes in opposite directions - in the same plane - they will INTERSECT - and you'll get a tapered version of 7a - roundest where the axes are closest together, more lens shaped as they get farther apart.
If you slant the axes in opposite directions - but in two separate planes - you get a tapered result like 7b - BIT - with a twist in it.
Now to a Top View
On the left (5) we've got the two 3D models of our two profiles.
6a shows how they'll overlap - and - the lens shape cross section of the "common volume" IF the two axes are PARALLEL TO EACH OTHER
7a shows the resulting "outcome"
Now here's what prototyping with Virstual 3D models can do for you - quck and relatively easy VARIATIONS
(think word processor or PhotoShop)
6b uses copies of our orignal Virtual 3 D turned profiles.
By "tilting" the axis of each in opposite directions relative to each other and THEN overlapping them, we get a TAPERED version of the PARALLEL AXES piece - fattest and most round where the axes are closest together, narrower and more lens shaped as the axes get farther apart.
Here's where it gets interesting - and something you CAN'T do in just 2D - TWIST.
Copy the "slanting" overlapped models of 6b
6c. Now offset one of the axes "planes" away from the other.
The axes "tilt" gives us a Taper AND a TWIST shown in 7c - which happens to be a Counter ClockWise Twist. Had the Blue Axis been offset in the opposite direction ,the result would be a ClockWise Twist
OK, now let's look at things from a diffent vantage pont - something SketchUp and other 3D modeling apps let you do that you can't do with simple 2D CAD.
Look at 7a, 7b and 7c.
Notice how 7b and 7c differ from 7a - they taper and 7a doesn't. 7b and 7c are fatter at the bottom and thinner at the top.
Also notice that the "lens" shape cross section starts getting flatter (not fatter but fLatter) when you tilt the two axesin opposite directions.
Finally, though it's tricky to see, that 7c has a TWIST to it. You can go from almost no twist to almost a 180 degree, or half twist" by changing the distance between the two "axes planes" Farther apart, MORE TWIST, closer together LESS TWIST.
Once you've got the profiles worked out and the resulting Virtual 3D "turning" done
, you can do variations in 15 minutes or so - and not be ankle deep in chips and shavings - and not used ANY wood - yet.
In addition to letting you SEE the "outcome" of an idea, this method lets you work out where the centers of each axis should be on you blank, shows you what the "outcome" should look like so you'll recognize it while turning to get it AND - what you did is Self Documenting - assuming you saved the file of the SketchUp Model(s) - and can find the file later (use descriptive file names - in this case I went with "Dill_MoonRising..."
Questions, comments, suggestions all welcomed.
