I guess few of my work
phillip Medghalchi
If I can somehow get the image uploading button on the bottom then we may succeed.
I guess the site won't let you upload pic.s any more/
Re: I guess few of my work
Complete the "My Profile" process
Greg Haugen
Phillip, It looks like you have a profile with this name. If you don't, click on the my profile button and complete the process. You're earlier post you used a different version with the name. Sign in with the My Profile button and then when you come back to the forum after that page you'll be under your profile and will have more options for posting, including pictures. When you come to the forum without cookies, you either have to go through the my profile page or post something for the site to recognize you under your profile with your name and password.
When you're editing a post while signed in your profile name the "browse" button for pictures is above the post, as well as for new posts.
If the size of the image is too large, the site will deny it so it can be re-sized. The size limit is 100Kb.
Any questions, just ask.
It's not the site!
phillywood
it doesn't work.
phillywood
I guess we have to go w/o pic.s, since the site is acting up.
I believe the site is working fine
GaryG in MD
Here's a pic of some pens as a test. ...GG
Greg Haugen
Phillip, I just sent you an email asking you to send me one or two of your photos. I will help you out. There's a few things that I can check on by you doing that.
PEBKAC
Hi Phil,
A coder friend of mine once told me his assessment of a similar situation: PEBKAC -- "Problem Exists Between Keyboard And Chair." I'm not poking fun here, but the problem is not with our forum software. All you need to do is be aware of how the software works, and then follow the instructions. A little patience will be helpful.
You clearly have a valid profile. I can tell that because your profile name shows up in blue, underlined, at the top of your post. [NOTE: Your registered name here is phillip Medghalchi, with a lower-case "p" in your first name. This is critical. I'll explain in a moment.]
The "Upload embedded file" button for registered users is under the text formatting buttons under the Subject text box. Depending on your browser, it will say either "Browse..." or "Choose File." If you don't see the formatting buttons or the smiley emoticons to the left, it means your WoodCentral cookie doesn't know you are a registered user, usually because you've got a typo in your user name. To check that, click on hte "Set Preferences" link in the gray navigation bar on the message index page. Be sure your name is spelled with a small "p" and that it otherwise matches the profile name I mentioned above. Click the Edit button to save any changes, then go back and try posting again. The smileys and the upload button will be there, and you can proceed with your post. Remember that any images you upload must be less than 100Kb in total file size. Refer to our FAQs file if you need any refreshers on file sizing or image uploading.
Ellis Walentine, Host
Re: PEBKAC
phillip medghalchi
I guess your friend was right and I didn't even pay attention to "p" in the first name and the "M" in the last.
Bellow is a spalted Bradford Pear inside finish Mike Mahoney's walnut oil finish( I wasn't too happy about it turning this wood so dark that it was beyond recognition of the spalting pattern. The outside was originally finished with mike's oil too, but wife did not liekthe darkness and I asked a freind who is expert at finishing wood to help me to wash it off and apply laquer finish. Dim.= 13 1/8" dia. x 4 1/4"H
Nice bowl
I don't mind the dark color, in fact, pear is going to go to that color eventually regardless of what you finish it with. Spalted wood, on the other hand, is usually somewhat punky to begin with, and any oil will really darken it. I'd suggest a sealer coat of shellac or lacquer. A lot of turners use Krylon Matte Finish or Fixativ Spray on spalted wood, to keep the color natural.
Glad you got your profile figured out.
